vermyapre
Electrical work cost??
wow good infor sharing...
Let the quotes fill in this forum so it can benefits us to know where to search for good electrician~ :yamseng:
Ya, still sourcing for one too.
Sorry guys, just would like to ask, is it that only licence electrical worker then can do wiring for our unit? Because I've check with my ID and she say most electrician in the market don't own the licence. And if will have to engage one with... The quote will be higher. Is that true? Is it die die must have licence then can???
wow... i thought most of the electricians got to get their so called "license" before they can run the works?
Seems like reverse method.
how to check electricians holding a valid license? Cant just ask them "r u license electricians" :thumbs up:
I heard from my ID, the electrical company sure have an LEW in the company to endorse the electrical works done by that company. But the workers in that company don't have licence. Hmm.. Confused
wow thats scary...
I even introduced JAE to my colleague~
But end up my colleague electrical work is small (not much profit)
JAE didnt return a call~
Well...i guess he's too busy with other "big" projects.
Haa, before i encountered all these problems with Sebastian, i also recommended a friend to him.
My friend's electrical work also very small and on the appointed day to do the electrical work, Sebastian didn't turn up. My friend called him many times and he also didn't bother to return calls.
yes. One big-sized local indian and 2 banga/indian foreign workers.
Three of them did the work badly, ccracked my kitchen wall tiles, uneven laying of casing. gave the big indian a fridge o the first day, he carted away, only to find out he left it on the lift lobby.
Strangely, it disappeared a week later when they were supposed to turn up to do the wiring. Sebastian and his workers went MIA, including the fridge too.
Seem we have the same workers, 1 big size local Indian and 1 very thin blanga/indian worker. The very thin blanga/indian worker is very hardworking albeit inexperienced. My casings were also unevenly laid with gaps at the adjointing corners.
Hi Guys,
What you think of my quotes
Lighting point $30.00
13A Single power point $45.00
13A double power point $55.00
TV point $90.00
Extend telephone point $15.00
Extend 13A Single power point $15.00
Reposition ceiling Lighting point $15.00
Oven, Cooker & Hood point $55.00
Install light $9.00
Door bell install $10.00
Hi all, got a quote for whole house rewiring. Can anyone please advise if the price is reasonable? Thanks in advance.
New lighting point - $30 x 46 = $1380
Installation of lighting - $7 x 46 = $322
New 2 way switch (5 sets) - $20 x 5 = $100
New 13x2 socket - $55 x 30 = $1650
New 13x1 socket - $45 x 3 = $135
New 2 way water heater - $125
New 20A Isolator (Aircon) - $90
New Hood and oven point - $60 x 2 = $120
New Telephone point - $30 x 4 = $120
New Tv/Cable TV point - $70 x 4 = $280
New Cat 6 LAN point - $80 x 5 = $400
New DB box (18 Way) - $200
Total = $4922
Less Discount = $422
Total Damage = $4500
Sure . most glad too.
was lucky tht Mr Lye picked up the call as i was looking for Ah Di from Zenterra as recommended here.
Understand form Daniel he is the boss.
Latest update, 2 more guys come down so now total 4 of them excluding Daniel.
U want me to email it to you??
Hi, can you PM me the quote as well?
Thanks in advance! :)
Hi Guys and Gals,
Is this consider cheap?
Items Pcs Price
1. 13Amps power points 17 in nos. $45 $765
2. Telephone 4 in nos. $30 $120
3. Internet cable 4 in nos $50 $200
4. Scv Cable point shifting 2 in nos. $30 $60
5. Shifting 13amps power point 1 in no $30 $30
6. Air Con Point $80 $80
7. Oven point 15amps $70 $70
8. Cooker Hood Point $50 $50
9. Lighting points 21 in nos $30 $630
10. Redo and fix all lose wires $200 $200
11. Change whole house switches $300 $300
12. Door bell wiring $20 $20
13. Install lightings 6 in nos $10 $60
Grand Total $2,585
Two questions....
1) i only have 15 downlights,
the calculations should be $30 x 15pcs = $450 (new points)
then to install 15pcs downlights should it be extra $10 x 15= $150??
2)
Install 13Amps power points 17 in nos for $45 normally do they comes with switches? Mine doesn't comes with it.
I have to change whole house switches for extra $300 :unsure:
Hi Guys and Gals,
Items Pcs Price
Grand Total $2,585
Two questions....
2)
1) you're right, installation of downlights are priced on top of the cost of 'pulling' the new point.
2) my electrician did not charge me for the cost of switches and powerpoints (normal MK brand). Maybe you're opting for those designer types of fanciful switches??
Edited by ken4228
Hi ken4228,
So for item1. He charges me wrongly. or think im a carrot head 8|
For item 2. single and double socket mostly are based on standard switches.
Only those 1 gang/2..3 are fanciful but i dont think it cost $300 for getting all socket and switches from him.
Most probably i will op out the $300 and go CCM to get my switch n gang.
Any installation will be charge if i provide my own switches?
Is my quote too exp?
Hi ken4228,
no, item 1 is correct. light pt 30 + installation 10 = 40.
it's the normal practice.
if u're asking him to change the switch/sockets on existing ones, he might charge u for installation fee unless it's those that are relocated or added power points. however, i believe most decent contractors out there will just do it FOC out of goodwill.
i suggest that if your electrician is charging installation for changing of the existing gangs, better u DIY yourself.
all u need is a test pen and ensure that the mains are off.
