vermyapre
Electrical work cost??
Hi
For those who engaged Eric, what switches did he give? MK Switches?
Before I confirmed with him, he said will be using MK.
When he finished most of the electrical work and I went back to see, he gave Feng Yip swithces (the rocker switches with a flower logo at the bottom right). He's not honest, he tot I dun know tat switch is from Feng Yip.
  • Like 1
So did u managed to get it changed ? Initially I thought that the switches we have to provide but it seems that the electrician will provide these.
vermilion, u also stay in telok blangah ? which blk ?
devilaz, u've got pm !
Can I check, how many of you actually asked for PUB testing since it's optional? There's much more freedom if you skip the test, if you decide to do the test, quite a few restrictions like height of DB box, number of heater points, height of plug in kitchen, etc ....
I'm in a dilemma.
I am doing a complete renovation of an old condo unit I bought.
The electrical costs my ID has quoted me are approx double that in the posts I have seen in this thread.
When I pointed this out to my ID, they asked if these prices I have seen are for concealed wiring.
So are the prices posted on this thread based on concealed wiring?
Some of the prices I have been quoted...
Single power point = $90
Double power point = $110
Light switch = $80
Light point = $60
Fan = $80
SCV = $220
Telephone & Data point = $220
Distribution board (32A single phase) = $340
Edited by stopspam
Light switch = $80
Light point = $60
Fan = $80
SCV = $220
**** ex. just like my ID, quoted me almost double of Eric's.
Eric is a lot cheaper.
His workers not bad, sometimes a bit forgetful and slipslop, but Eric will tell them to do again if not right.
As for the MK switches I stated above, Eric can change to MK.
But in the end, I refused, cos he's giving MK slimline series, not avant series.
Slimline is worse than Fung Yip switches.
Slimline is so hard to press and so ugly, Fung Yip is smooth to press and chamfered and the edges.
Hi all,
I had just gotten a quotation from an electrician (refer below). My place is a landed property (corner terrace). From what I see, he is charging very much higher than what some of the guys here have posted. Is it because mine is terrace? Or is he just charging too high?!
BTW, I don't see any indication of PUB testing.
SCV Point - $150
Single 3 pin Power Point - $60
Double 3 pin Power Point - $70
Telephone Point $80
2 way light switch - $180
Lighting Point - $75
BTW, mine is not concealed points.
All power points, switches are layed using PVC casing.
Edited by hayashiryo
I would like to find out if anyone has engaged Mr Quek's service, as I have found his charges not that transparent after all. I dont know if he has too many projects in hand, he is quite forgetful and has charged me for the work which I told him initially to do, but dont need him to do at the end. Anyone has smiliar experience?
Normally prices are for non-concealed wiring. Independent electricians do not normally quote concealed wiring as the hacking and replastering is done by the general contractor. Your ID probably giving you a package price including hacking and replastering.
Light switch = $80
Light point = $60
Fan = $80
SCV = $220
I just finalise my rewiring job. Its for 4-rm.
Prob u might be interested :bangwall:
Light point. (Wiring + light fitting installation.) - $35x17
Loopping point. (Wiring + light fitting installation.) -$25X11
Door bell. (Wiring + insall + switcher.)- $25X1
2x13A SSO. - $50x5
1x13A SSO. - $40x9
Hood & Hob point. - 1set $45
15A air-con point. -1X$75
Water heater point. - $80X2
SCV point. (Living hall) - 1X$70
Tel. Point. (Living hall) - 1x$45
Complete set of electrical DB. - 1set $220
Earthing $50
Total spent 2170
May not be the best price but its up to individual. I did manage to get a $1300 package for the above. Excluded installation and some other charges. The electician did not reveal much so i did not much what he meant by other charges. The highest quote u received was 2.5K wiith no installation included. I almost fainted...so x!:sport-smiley-004:! Its was recommened by my contractor. Thats' why i begin to find my own electrician. Hope the above can provide a gd reference.
Cheers !!
Why do u need a complete set of DB? Just wondering why is there a need to change the DB... I was recommended by my ID to shift the DB in order to cater for my shoe cabinet. Is it safe to do that? What happens if the electrician did not do a good job?
Hi Guys,
What you think of my quotes
Lighting point $30.00
13A Single power point $45.00
13A double power point $55.00
TV point $90.00
Extend telephone point $15.00
Extend 13A Single power point $15.00
Reposition ceiling Lighting point $15.00
Oven, Cooker & Hood point $55.00
Install light $9.00
Door bell install $10.00
Hi Guys,
TV point $90.00
Install light $9.00
I need to rewire my entire place cos very old. Can share your electrician contact?
Thanks very much
I was quoted
$120 for submission& single drawing
$120 for apply SP services testing
$220 for E.L.C.B
Is that necessary? I am doing rewiring for my 4rm resale.
Also I was quoted for both 13amp single and double switch. Isnt double enough? Total cost ended up to be ard $2.8k! I though this was ridiculous... someone pls let me know if this is the normal rate?
Hi De_princess,
$2.8K expensive or not depends on the number of lighting points, power points, heater/hob & hood points, SCV point (around $95/point), phone/fax points, DB Box (most expensive item around $350), etc... you have.
Are you changing the Main Cables? Recommended if your place is very old and going for SP testing.
Usually SP testing cost is around $250-280 but some ID electrician will recommend using metal casing (which is an extra cost if a lot of metal casing involved) for the wiring (especially behind feature walls, walls, wardrobe) for SP testing so that in case you drill in future you will not drill the cables directly.
Cheers :notti:
I was quoted
$220 for E.L.C.B
Edited by lifestyle
Hi De_princess.. i was also quoted 2.8k for the whole hse, 5rm! got a shock.. i'm getting them to send me the breakdown.. can share with me your quotation?
