lazy_tiger81
Pls Help Assess My Quote (p@d 5 Rm)
Hi brothers and sisters,
Just got my keys and planning to do some minor renovation. Have alot of carpentry due to wall to wall bookshelves in living room. Is my quote reasonable? The ID is quite well known for good carpentry. Thank you!
A Professional Services
1 Design & site co-ordination
2 Space planning layout plan
3 Perspective drawings on all carpentry works
4 Warranty of workmanship & after sales services for 5 years
5 Arrangement for PUB gas pipe installation
6 Consultation on selection of lights, furniture & accessories
B Masonry Works
1 Supply & construct base for kitchen cabinet & fridge with matching floor tiles
2 Haulage loading of sand, cement & materials to unit
C Plumbing Works
1 Connect inlet & outlet piping for kitchen sink
2 Supply labour to install storage heater or 02 nos. of instant heaters
3 Supply labour to install accessories @ both bathrooms
4 Supply labour to install kitchen sink, hob & hood
D Ceiling Works
1 Supply & install false ceiling or light box @ living & dining
2 Supply & install false ceiling @ foyer & passageway
E Painting Works
1 Supply & apply 03 coats of Nippon paint to all internal walls & ceilings ( max. 8 colours )
2 Supply & apply Nippon gloss paint to all water piping, gates, door frames, & sewage pipe
3 Supply & apply paint or varnish for all existing doors
F Miscellaneous
1 Supply & lay protection sheet
2 Clean up whole unit with chemical
G Custom Made Build-in Furniture - All Laminates from Germany or Italy with solid ply wood
Master Bedroom Area
1 Design & fabricate full height wardrobe in laminate finish c/w swing doors ( max. 6ft L )
Kitchen Area
2 Design and Fablricate top and bottom kitchen cabinet in laminate finish c/w 04 sides ABS
trimming swing doors cuttlery tra 02 pcs glass panels and designer handles.
3 Supply and install stainless teel dish rack with hydraulic lift up 04 sides abs trimming door and glass panel
Total Amount : $9,333.00
PLUS
H Free Item
1 Free solid surface worktop 12ft L worth S$960.00 F.O.C
2 Free Delizia slimline hood & hob ( KREA 90IX & DZX730 ) worth S$878.00 F.O.C
( While Stock Last !!! )
Additional Items
I Hacking Works
1 Dismantle existing wash basin @ master bathroom area Lot $80.00
Total Amount : $80.00
J Glass Works
1 Supply & install 10mm thick clear tempered glass fixed panel @ common bathroom 21 sqft $315.00
2 Supply & install 10mm thick tempered glass shower screen @ master bathroom c/w
swing door & L-shaped handle 1 set $550.00
Total Amount : $865.00
K Custom Made Build-in Furniture - All laminates from Germany or Italy with solid ply wood
Living & Dining Area
1 Design & fabricate feature wall cum shoe cabinet @ household shelter area in
laminate finish 8 ft $1,760.00
2 Design & fabricate full height book cabinet in laminate finish 13.5 ft $3,510.00
3 Design & fabricate study table c/w drawers in laminate finish 10 ft $1,500.00
4 Design & fabricate suspended book cabinet in laminate finish 10 ft $1,500.00
Total Amount : $8,270.00
Master Bathroom Area
5 Supply & install solid surface worktop as vanity's top 3.5 ft $245.00
6 Design & fabricate suspended vanity cabinet in laminate finish 3.5 ft $315.00
7 Supply & install wall to wall mirror 3.5 ft $210.00
8 Supply labour to install new wash basin & tap 1 set $60.00
Total Amount : $830.00
Kitchen Area
9 Design & fabricate full height tall unit cabinet in laminate finish 2 ft $600.00
10 Design & fabricate feature wall @ kitchen entrance area in laminate finish 8 ft $1,440.00
11 Design & fabricate top hung wooden sliding door in laminate finish 3 ft $720.00
Total Amount : $2,760.00
Total Package : $9,333.00
Total Additional : $12,805.00
Sub Total : $22,138.00
Less 5% discount : $1,106.90
Grand Total : $21,031.10
Comments anyone?
I'm just wondering if the carpentry is considered too expensive.
No way to compare, unless you can post the furniture design and material model :P
Hi there
I too just got a place at P@D; Blk 1F; which block are you at?
Could you pls PM me your contractor's contact details?
Thanks
Meena
Hi
At a glance it is reasonable, even cheaper than mine. anyway, I assume u had did your research on your ID before u post this info. U may wanna to make sure the ID can hand-over based on your require date. what is the payment like 30/30/30/10 or 10/40/40/10?
Also make sure u got "chemistry" with the ID.
