beanbeanlim
Budget Kitchen Renovation
Hihi I m a newbie here :D
I plan to do a simple kitchen renovation on my kitchen. I m staying in a 4rm resale flat n my kitchen is kinda of old thou de kitchen cabinet that is left by the previous owner still can be use. My plan is to remove all the cabinet in the kitchen and replace a new one but just a few top n bottom cabinet cause I don't like to have alot of empty cabinet :P , the stove area and the sink that all. Due to budget wise I thought of getting a soild top for my kitchen may I know roughly how much will it cost TIA ;)
Edited by beanbeanlim
Hi Lim,
pricing for cabinets usually calculated in per foot run.
30 centimeters is 1 feet.
if your cabinet is 3 meters long then it will be calculated as 10 feet.
top cabinet 3 meters 10 feet, bottom cabinet 3 meters another 10 feet, tat equals to 20 feet.
Most carpenters charge between 75 to 90 dollars pfr for standard specs.
$90 pfr will be $1800 for a 20 feet kitchen cabinet EXCLUDING solid surface top.
solid surface top cost from $65 to $80 pfr depending you are getting from a contractor or from a ID firm.
At $80 pfr, a 10 pfr solid surface top will be $800.
The pricing above usually does NOT include disposal of your existing kitchen cabinets. that is a seperate charge.
fyi base on my own experience
Hi Lim,
Thank you for the info given... My budget is less than 5k just for doing the kitchen is it possible?
My ccontractor charges me 90-100 pft for cabinet and solid surface is 70pft. Hope these help! if you need the contact can just Pm me.
Yes it is possible.
eg. 20 feet kitchen cabinet $1800,
10 feet solid surface top at $800,
dismantle and dispose of kitchen cabinet $300
purchase a turbo hood & hob package price $600 +/-
purchase a standard double bowl kitchen sink & normal sink tap $200 +/-
Total is $3700, can be done!
Under 5k is possible if u do not request some expensive surface top like marble and solid wood cabinet. My contractor recently finish one of my friend old house kitchen, and he take extra effort to reconnect the electrical cable and power ppint (he work as an engineer last time), which save her some money. ;)
since u wanna hack all the kitchen cabinet then u have to think of the affected wall are behind existing cabinet..u have to retile it again and not to forget your cabinet base since u gonna do just few cabinets only..all tat cost money..luckyly my contractor is an honest chap.he told all this b4 hand so tat there wont be any disagreement later part.
the possible issues you may face are: tiling, plumbing, plastering, cabinet base, disposal, electrical, painting, backsplash
Thank you for all the advice n contact given now doing some homework n asking for quotation :P
Hi beanbeanlim can i check with you whether have u done ur kitchen reno?? Cause recently i have decided to redo my kitchen, on a tight budget and just want to see whether how much did u do for ur kitchen reno??
