ninja3101
Anybody House Got Do Network Or Lan Points ?
Hi All
My ID's electrician quote me the prices for installation of 1 Nework/LAN Points
1) $45 - (I have to provide the LAN cable to them)
2) $85 - (Using Cat 5E cable)
I am asking my ID whether can change to Cat6 instead.
So is it ex for per LAN point ? Anyone house got do Lan Points ?
I wanted to have Gigabit LAN @ my home but decided against it.
If I am hosting a home server with many big contents for the rest of the house, I would need gigabit.
Since I would be mainly use for internet and the maximum speed of broadband in Singapore is still stuck in 100 mbps, what for? I can use wifi.
Even if they have faster connection (with opennet) i doubt the price would be cheap. And I would still be using the cheapest option and wifi would be good enough.
Hi All
i did my 12 LAN points at home for my 4 room. each faceplate has 2 points, cost is 25$ per faceplace. total is 150$
I provide cabling and the K.O box, contractor provide pvc trunking and labour.
Cat 6 is thicker and harder to bend than Cat5e which is sufficient to carry 1 Gbps in house but no pc/laptop today can truly transmit 1gbps. max 200-300mbps.
so cat5e is more than enough.
in future, OpenNet will install fibre in your house and Nucleus Connect will provide 1gbps to your house.
Hi keocovn
Thanks for your explanation. U have clear my doubts. :D
How much did u spend on the 1 Box of Cat5e cables & K.O Boxes ?
So u think my ID charges r ex for installation of LAN Points ?
Hi keocovn
my cost is 25$/pt. your is 45$/pt. what do u think?
i did not know the cost of cabling and K.O box. got it foc from someone.
Of course yours cheaper.
Edited by ninja3101
I did my own termination for my network points. But my contractor run the Cat6 cable for me. :D :D
I went to ask a shop in Sim Lim Tower , must buy 1 box of Cat6 cable @ $250 .
Which shop in sim lim square u bought your Cat6 cable from ?
How many LAN points did u install in your house ?
How much the contractor charge u for the laying ?
Edited by ninja3101
I do have about 200+ metres of AMP Cat6 cables left.
Can sms me at 92727500 if you're keen to buy.
Collection in the west.
My contractor doesn't do the cabling, can keocovn refer me his contractor?
I'm also keen to the cable jervislim has.. can take a look?
thanks for the offer but I will be sharing with my fren. So need to buy one box 300M. Anyone knows which shop sell cheap Cat6 300M in Sim Lim Square or Tower ?
Keen to get abt 50-80m from you. Still available?
Yes, pls sms me for arrangment/querries.
Had private msg you... Check inbox.
Edited by jervislim
I don't know where he bought it from.
4 points in the living room next to the opennet box to each room master, guest and playroom ( playroom 2x ).
He told me $200, but did not charge me at the end.
