velv 0 Report post Posted March 16, 2010 (edited) Hacking is usually very cheap and should be completed in 1-2 days, so below $1k seems possible... ooh I see, this is great cause that means we might be able to save some if we look carefully enough for direct service though we also got to take note that hacking needs permit and the fella must possess a housing board license rite? Edited March 16, 2010 by velv Share this post Link to post Share on other sites
velv 0 Report post Posted April 6, 2010 ~ Love this so much , but its juz too biggg~ argh Share this post Link to post Share on other sites
velv 0 Report post Posted May 9, 2010 (edited) Went over to new house to look at the air-cons again. As we had conceal piping with the exisiting Daikin systems 4 piping. We like to remain using back the current piping to our new Mitsubishi System 4. If not .. we had to hack away the cornices in order to install the new aircon. Our hacking is on Wednesday so we need to look into this fast. Will be asking the aircon contractor to come have a look asap.. Need advise whether the outdoor units piping are alright? - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Edited May 9, 2010 by velv Share this post Link to post Share on other sites
velv 0 Report post Posted May 9, 2010 (edited) Correct Way of Measuring your Toilet Bowl : Edited May 16, 2010 by velv Share this post Link to post Share on other sites
velv 0 Report post Posted May 9, 2010 (edited) Edited May 9, 2010 by velv Share this post Link to post Share on other sites
velv 0 Report post Posted May 9, 2010 *Scare that people will make use of service yard to peek into the bathrooms.. umm any ideas? Share this post Link to post Share on other sites
purecat 0 Report post Posted May 9, 2010 *Scare that people will make use of service yard to peek into the bathrooms.. umm any ideas? can apply permit to change to dark sliding window ? then keep it closed ( or covered ) ? Share this post Link to post Share on other sites
velv 0 Report post Posted May 9, 2010 (edited) 2-way (from MBR, punch into living room) found a electrician charge S$140 installation of heater point + labour & materials & supply new 2-way tap to change current mixer tap electrician charge S$150 Replace new fan : S$50, Install new fan : S$40 Replace all Switches bundle : S$250 Replace light : $8 each Replace downlight 20mm : $5 each Edited May 9, 2010 by velv Share this post Link to post Share on other sites
velv 0 Report post Posted May 9, 2010 (edited) Switches Count Down Change to 3-gang switch instead. convert dimmer to normal down lights Change to 2-gang switch instead. convert dimmer to normal down lights Change to 1 x 2-gang switch and 1 x 3-gang switch instead. convert dimmer to normal down lights Edited May 17, 2010 by velv Share this post Link to post Share on other sites
velv 0 Report post Posted May 9, 2010 (edited) Change to 3-gang switch instead. convert dimmer to normal down lights Edited May 17, 2010 by velv Share this post Link to post Share on other sites
