mersing
How To Remove Nail With Hook
  mersing said:
How do I remove nail hooks without damaging the wall? The ones that I have look like these.
Is there some special tool that I must get?
You might damage the plaster on the wall by using force to remove the hooks. You can also do it by inserting a small screw driver behind the hook and prying it out/loose.
Be prepared to patch up damged plaster, Get a pre mixed putty plaster for $2.00 to fill up cracks for repainting or touch up.
Edited by fierydragon
fierydragon, I've actually tried using a small screw driver as I didn't have a plier at home. It didn't work cos the strength of the screwdriver is not there. I just couldn't get behind the nail hook and pry it loose.
Yes, I will use the pre mixed putty plaster that you have suggested to patch up and do some touch up. Thanks.
Any suggestions for paint that is peeling off the ceiling? Some patches fell off especially during the damp rains period. I didn't want to repaint the whole unit cos in 2 years' time, I'm surrending this unit back to HDB. I know they are particular about nail issues on the wall. That's why I'm taking them off here and there before returning it back.
Edited by mersing
The paint peeling is called "Spalling" and is caused by your neighbour upstairs. Contact HDB to complain.
how to complain to HDB? what to say? HDB usually say not their fault leh.
by removing it with cutting plyer without bending them or twisting them with a hammer
