ahwong 0 Report post Posted January 13, 2010 (edited) 2 identical pcs, about 30cm x 70cm, 18mm thick. One side with white backing, total $20 Got it from a workshop at blk 9008 tampines st 93. He is kind enough to drill the hinge holes (35mm dia) for me.. Extremely nice after fixing.. I thought it is cheap. what do you think? I need a lot more in near future. if you have better lobang, pls share share.. Edited January 13, 2010 by ahwong Share this post Link to post Share on other sites
ahwong 0 Report post Posted January 13, 2010 (edited) .. Edited January 13, 2010 by ahwong Share this post Link to post Share on other sites
lorddraco 1 Report post Posted January 13, 2010 2 identical pcs, about 30cm x 70cm, 18mm thick. One side with white backing, total $20 Got it from a workshop at blk 9008 tampines st 93. He is kind enough to drill the hinge holes (35mm dia) for me.. Extremely nice after fixing.. I thought it is cheap. what do you think? I need a lot more in near future. if you have better lobang, pls share share.. Hi ... I got similar size. 8.5" x 22", 3/4" thick and 4 3/4" x 16.5", 3/4" thick (Non-White backing- I donno about the price). $4 at Ban Heng Leong. But they did not drill hole for me. I am not sure if that is consider cheap or expensive cause also need to compare the quality of the ply. Share this post Link to post Share on other sites
limlim 0 Report post Posted January 13, 2010 Hi ... I got similar size. 8.5" x 22", 3/4" thick and 4 3/4" x 16.5", 3/4" thick (Non-White backing- I donno about the price). $4 at Ban Heng Leong. But they did not drill hole for me. I am not sure if that is consider cheap or expensive cause also need to compare the quality of the ply. His is furniture store market rate. i was told per foot square for 3/4 plywood is 3 dollars. So if 8.5" x 22", should work out to about 6 dollars a piece. The other piece will be about $2.25. So about 8 dollars for both. Plus drill one hole 5 dollars maximum. 2 holes works out to $18. So both actually about same price. haha. Share this post Link to post Share on other sites
lorddraco 1 Report post Posted January 13, 2010 His is furniture store market rate. i was told per foot square for 3/4 plywood is 3 dollars. So if 8.5" x 22", should work out to about 6 dollars a piece. The other piece will be about $2.25. So about 8 dollars for both. Plus drill one hole 5 dollars maximum. 2 holes works out to $18. So both actually about same price. haha. IC .. furniture store will need extra margin. I think ok ba. Share this post Link to post Share on other sites
ahwong 0 Report post Posted January 13, 2010 Hi ... I got similar size. 8.5" x 22", 3/4" thick and 4 3/4" x 16.5", 3/4" thick (Non-White backing- I donno about the price). $4 at Ban Heng Leong. But they did not drill hole for me. I am not sure if that is consider cheap or expensive cause also need to compare the quality of the ply. I thought I have a good deal, yours even better... dont think drilling holes is a big deal for them, standard 100mm from the edge, took less than 1 min per hole... I will visit Ban Heng Leong... I will go for both side with white backing... still have a few cabinet doors to make.... Share this post Link to post Share on other sites
ahwong 0 Report post Posted January 14, 2010 Hi ... I got similar size. 8.5" x 22", 3/4" thick and 4 3/4" x 16.5", 3/4" thick (Non-White backing- I donno about the price). $4 at Ban Heng Leong. But they did not drill hole for me. I am not sure if that is consider cheap or expensive cause also need to compare the quality of the ply. Ban Heng Leong is at where er? Share this post Link to post Share on other sites
lorddraco 1 Report post Posted January 14, 2010 Ban Heng Leong is at where er? No 11 Syed Alwi Road #01-07 Teck Heng Long Ind Building Jalan Besar area! PS: very near to a very nice/shiok beef ball noodle shop. Share this post Link to post Share on other sites
