davidngeb
Furniture Repairs And Carpentry Works
Avertising post removed
Hi.
Can provide your individual best quote & materials use as follows:-
Living
1. 6ft(L) x 7ft(H) - TV wall feature with laminate finished @ living room together with 6 ft suspended console attached to TV wall feature with aluminum frame glass doors @ living room
Bedroom 1
2. 5.5ft(L) x 10ft(H) - Aluminium frame glass panel sliding door with casment door above wardrobe
Master Bedroom
3. 4ft(L) x 4ft(H) - Feature wall with 4 ft suspended console join with L-shade 10ft wardrobe c/w 2 panel sliding aluminium frame (Full Height: 10ft(L) x TV Console: 4ft(L) - Total 14ft)
4. 3ft(L) x 7ft(H) - Altar cabinet with laminate finished
thank you :)
do you provide relaminating service for built in wardrobe and shoe rack? (both inner and outer layer)
We do but it can be quite costly may not be justifiable
Hi David:
Can you pl quote :
a - 1 x wood rack, W34.5 inch x D 14.5 inch x H 10 inch, made of 1 horizontal piece and 2 vertical side pieces.
b - Plain wall-mounted shelves, one piece measuring W 80-cm x D 50 cm to support 1 dry cabi and 1 PC, and another set of 2 shelving pieces W 140cm x D28 cm for books, and 1 printer-copier m/c.
Either stained (or spray-painted white) solid pine, kapor or ramin wood or melamine glossy white laminate.
TIA !
