saltnlight
Quotation Too Good To Be True?
hi all,
Just wanna check with you guys the below quotation for a 5-room resale unit(complete overhaul). Are there any hidden costs in it?
Special Elegant package for 5 room(RESALE FLAT)
Professional Management / Design Service
1 Conceptualise space planning
2 Conceptualise layout planning
3 Colour / material matching & proposal
4 Perspective drawing by registered interior designer
5 Interior element & product pre-consultation
6 Site foreman supervision
7 Project management with ISO standard
Masonry Work
8 Hacking of living & dining hall flooring
9 Hacking of bedrooms flooring
10 Hacking of kitchen flooring what about wall tiles?
11 Hacking of 2 bathroom flooring what about wall tiles?
12 Supply & lay 600 x 600mm homogenous flooring for living hall which country are the tiles from?
13 Supply & lay 600 x 600mm homogenous flooring for dining hall
14 Supply & lay 600 x 600mm homogenous flooring for bedrooms
15 Supply & lay 600 x 600mm homogenous flooring for bomb shelter
16 Supply & lay homogenous skirting for whole unit
17 Supply & lay 300 x 300mm homogenous flooring for kitchen what about wall tiles?
18 Supply & lay 300 x 300mm homogenous flooring for 2 bathroom what about wall tiles?
19 Supply & lay high density water proofing membrane for kitchen & 2 bathroom
20 Construct main entrance kerb if applicable
21 Construct 50mm cement mortar washing machine base with tiles finishing
22 Construct 50mm cement mortar fridge base with tiles finishing
23 Construct 50mm cement mortar kitchen cabinet base with tiles finishing at expose area
24 Construct 50mm shower kerb with tile finishing for master toilet
25 Construct 50mm shower kerb with tile finishing for common toilet
Ceiling Work
26 L-box cornice for living hall
27 False ceiling at balcony
28 False ceiling for foyer area
29 False ceiling / L-box for master bedroom
30 Design cornice for bedrooms
Plumbing Work
31 Stainless steel piping for whole unit including washing machine tap
32 Inlet / outlet piping connection for kitchen sink
33 Inlet / outlet piping connection for washing machine
34 Inlet / outlet piping connection for 2 bathroom
35 Supply & installation of chrome mini spray jet for 2 bathroom
36 Supply & installation of Civic instant heater for 2 bathrooms including two-way tap
37 Supply & installation of 7 pcs toilet accessories for 2 bathroom including mirror
38 Supply & installation of pedestal bowl for 2 bathroom
39 Supply & installation of wash basin for 2 bathroom including tap
40 Supply & installation of stainless steel sink including tap
Painting Work
41 Painting for whole unit wall surface ( ICI / NIPPON )
42 Painting for whole unit ceiling surface ( ICI / NIPPON )
43 Emulsion coating for whole unit
44 Painting for all piping
45 Painting for all door frames
46 Painting for all doors
47 Patching of groove line if applicable
Aluminium / Glass Work
48 Supply & installation of 10mm wall to wall temper glass shower screen for 1 bathroom
49 Supply & installation of aluminium bi-fold door for 2 bathroom complete with frame work
50 Supply and installation of classic doors For all bedrooms
51 Supply and installation of galvanized Wrought iron gate
52 Miscellaneous
53 Supply and install door bell
54 Spring cleaning for whole unit
55 HDB permit handling fee
Total cost of the package for 4 room flat $18,700
FREE
Branded System2/3 aircon
OR
20 ft laminate kitchen cabinet including ABS trimming ,Designer Handle, Stainless
steel dish rack and 2 glass panel @$888
hi all,
Masonry Work
Ceiling Work
Plumbing Work
Painting Work
52 Miscellaneous
FREE
OR
Thats really cheap. most of the packages will be from 23888 onwards. this is way too cheap and too many items.. funny looking packages. better to those form the more normal ones. theres alot lot of packages around so far yours is the cheapest of them all with a huge jump on items and prices.
My 4 rms HDB flat cost me about $40k. See my T-blog for more detail.
One of the lowest quote I got. Some quoted me as high as $57k :P
Good luck
1) did not mention price range of tiles to choose from. eg S$2.50 psf? or S$3.50 psf? in my case, mine is up to S$3.50 psf. i have a piece of MBR toilet wall which i chose a tile of S$11.50 psf, but my ID 'absorb' it. cos for other tiles, i chose cheaper ones. so its a give and take thing.
2) as long as it did not mention in the quote, then it is not included. for eg, hacking will be hacking. no supply of tiles to lay or whatsoever. if never mention wall, then its also not included.
