thirdrockdweller
Project Home
Is the lights using halogen or enerery saving bulbs?
Should be energy saving bulb. AFAIK, halogen is only able to produce yellow light.
Hi samgalz,
It uses an E27 bulb. Wattage and type (Energy saving or otherwise) is up to the user.
I went with a 75W incandescent bulb. The shade of the lamp is actually a series of polycarbonate lenses and with the bulb turned on, the bulb is visible through said lenses. Somehow, the traditional shape of an incandescent bulb (as opposed to the modern compact fluorescent lamps) looks nicer and I believe convey the intended effect of the design (Lighthouse).
Ultimately, this is highly subjective and an imprecise science. To each his own. Nothing wrong with using either ;)
Edited by thirdrockdweller
Hi samgalz,
Erm, how much is the lamp btw? I like the effect. I wonder if I use an energy saving type of bulb will it be bright enough to light up the dining area
What i learn from the design process, don't think too much whether the dining pendant would be bright enough to light up the area.
A dining pendant is used more for decoration & accent purpose. To brighten the area, you would depend on other lights (eq. downlights).
Retails for $515 but got it knocked down to about $450 :)
I guess you could have different bulbs tested out @ the shop. Nothing like a good experiment :)
Totally agree :D
Yeah, I know, i am trying to balance functional and aesthetics, as the dining area is like 2.5m2 only, and trying to save cost of building extra lboxs in some area :P
You can install some spotlights on your ceiling directly. This way, you don't need to get L-box.
As in those that hang on a rod type? I wonder is there any energy saving lights.
for me no Lboxes or cove lighting so got to think of something else
my hubby love lboxes but I have too many false ceilings already, I was thinking of doing something different for dining area. Sigh, looks like i still have to do some.
Paiseh 3rdrockdweller, side tracked ur thread. :P
DIY Project 1 - Completed!
A dozen of this (Ikea Lampan)
+ some time + Lots of patience =
The Dodecahedron Platonic Sun
Found the plan to build this off the internet sometime ago and I told myself I just had to make one. Was originally intended to be hung above the study table but that was before I realized how ridiculously massive this thing is :o . It has since been repurposed into a floor lamp ;) Nevertheless, I still have a faint urge to have it be my study room pendant lamp. We'll see :)
Great effort! :good:
