shinzika83
Our New Lovely Home.....
Our new place HOme sweet Home.
Hehe Trying to Figure out how to upload my Floor plan hehe.
Hi welcome to reno T-Blog. To post a pic, first upload your pictures to photobucket (www.photobucket.com). You will have to register for an account with them first. Once the picture is uploaded, click the "insert image" button in the post window. You will be prompted to input the link. Now go to your photobucket album and copy the link under the IMG code and paste it here. The link should be bounded by "%7Boption%7D" on both sides when it appears in the post window. You can preview to check that you are successful. You can also click here to learn more. Hope this helps and looking forward to see your floorplan and pics :)
Can Some Kind soul help me see If my quotation is ok. Thanks
ALTERATION AND ADDITIONAL WORK
A.WETWORK
1.To supply and lay selected homogenous/ceramic wall S$2930.00
tiles to master and common toilet area up to ceiling ht.
2.To construct low ledge with hollow block and wall S$200.00
Tiles and both toilet.
3.To supply and lay selected floor tiles to both S$980.00
toilet c/w water proofing.
4.To construct shower curb to both toilet. S$160.00
5*.To supply and lay selected homogenous floor tiles S$6000.00
to Living, Dining, walk way to rooms, store & 3 x
Bedrooms include skirting.
6*.To supply and overlay selected homogenous floor S$680.00
tiles to kitchen floor include skirting.
7*.To cement plaster kitchen wall to receive skim coat S$590.00
plastering.
8*.To supply & lay wall tiles between top and base unit S$530.00
At kitchen area.
9*.To supply and lay feature wall at balcony area. S$860.00
B. SANITARY & PLUMBING WORK
1.To provide material & labour to run stainless
steel piping to:
a. both toilets-WC, basin, and shower mixer }
b. kitchen sink and washing machine area } S$1150.00
2. To provide labour to install the following items}
a. kitchen and both toilet sink tap }
c. toilet accessories }
d. 1 x central heater. }
3.To supply labour to install mixer tap and shower S$200.00
Set for both master and common toilets.
4.To supply labour to install wash basin and tap S$160.00
for master and common toilets.
5.To supply labour to install WC for master and S$180.00
common toilets.
*.All accessories and fitting supply by client
C.PAINTING WORK
1.To provide labour and paint (ICI) to paint whole internal S$1350.00
wall and ceiling in emulsion paint.
(Include room 2 and kitchen)
D.SKIM COAT PLASTER WORK
1.To supply labour & material to skim coat plaster S$1900.00
Whole house internal wall and ceiling.
(Include kitchen expose wall)
E.ALUMINIUM AND WROUGH IRON WORK
1.To install selected aluminium bi-fold door with S$360.00
acrylic panel to master & common toilet.
H. FASLE CEILING WORKS
1.To supply and install false ceiling to: S$2300.00
a. Living hall
c. Box-up master toilet PVC pipe(master board)
d. Box-up common toilet PVC pipe(master board)
e. Box-up kitchen PVC pipe above the basin.
f. Box-up kitchen PVC pipe next to cooking hob
(master board).
2.To do general cleaning to whole house- FOC S$200.00
CARPENTERY WORK
A.LIVING AND DINNG HALL.
1*.To proposed laminated flooring to balcony area. S$620.00
2.To proposed design divider feature in selected S$960.00
Timber strip finish between balcony and dining hall.
B.KITCHEN
1a*.To proposed top hung and base unit cabinet c/w S$2730.00
swing door, drawers, shelves, box-up PVC piping
in selected laminate finish with ABS trimming.
C. MASTER ROOM
1*. To proposed wardrobe c/w swing door, hang S$1950.00
rods shelves and drawers in selected veneer ply
or laminate finish with ABS trimming.
(base on new proposal)
ELECTRICAL WORK (Provisional sum)
DISCRIPTION
1. 13A x 1 power point
2. 13A x 2 power point
3. Telephone point
4. TV point SCV
5. 5A lighting point 1 way
6. 5A lighting point 2 way
7. Dimmer switch control
8. Install (simple) light fitting
9. Install ceiling fan
10. Door bell point & installation
11. To run speaker cable
(inclusive of cable)
12. To run earth point
13. Cooker hob and hook point
14. 15A air-con point
16. New DB box
TOTAL SUM: S$2,796.00
It is quite difficult to tell if the price is reasonable or not unless the dimesnions are given. For example, is you kitchen cabinets 20 ft? How about the feature walls?
Hihi.
I 2nd that. For your tiles, it did not specify what is the price range which you can select also.
This is my Floor plan Hope its clear enough. Actually have a copy of clearer wan its under PDF file dunno how to change to paint file so that I can upload.
Edited by shinzika83
sgk
I have uploaded a floor plan I dun think its clear .Do u have any idea if I have a pdf file which is much clearer any way how can I upload ? Thanks
Hihi.
For the tiles my ID say if would be range like $2.5o Around there homogenous tiles.Thanks
sgk
cchange the size of the picture using the view button of the acrobat reader until the picture more or less fill up the whole screen. Then press the printscreen button to capture it and open the program Paint, paste the captured image on it. Then save as jpeg and upload :).
Cant le I think I too stupid le hehe . Will try harder Thanks anyway
