Caireann
Plastering Of Ceiling Question
I read in the HDB renovation guide that plastering of ceilings is not allowed.
On the other hand I have seen falts where the previosly lousy looking ceiling has been plastred.
Does anyone know whats going on here?
Here:
OpenDocument
it sais:
Examples of Renovation Works Not Allowed:
Plastering of ceilings.
Edited by Caireann
Indeed quite interesting clause, who will apply permit to do "ceiling plastering"? False ceiling is more cost effectiveness than making ceiling uneven than do a plastering. The ceiling painting itself already very tiring.
Now I know why all walls in the flat I bought look smooth while the ceiling looks rough.
The renovation guide shows where have to apply and where not.
Since the ceiling is not mentioned in the main part I think everyone just assumes: no need to apply permit because its nothing much.
Plastering is not allow for HDB ceiling, but you can go for skimming.
Skimming is a applying a very thin layer of finishes on to the ceiling to make it more even.
but the existing paint must be remove before application.
actually why is it not allowed huh ? curious to know also. because planning to do for upcoming flat.
i recheck my old quotation, it did say plastering of ceiling- two bedrooms ( but we dunno if the contractor then did apply permit or not )
how to tell if it is plastering or skimming ?
the concern is what will happen when HDB come check the flat after we submit the resale docs.
Plastering consist of cement, sand and water. The thickness of plater is 5 mm or more.
Skimming consist only powder mix with water and is like a flour mix. The thickness is not more than 2mm.
The weight of a plaster is much more heavy than skim coat, if not done correctly, the plaster will fall off from the ceiling.
icic thks.
