furion0000
Advice On Quotation
As far as I know, wood for cabinets, etc...there are 3 types...
1) Plywood (almost every contractor use this cos harder, better and stronger)
2) Compressed wood (minority of them maybe uses this...but not so good not durable)
3) Gypsum board (its commonly use for false ceiling, wall, etc...not suitable at all for cabinet and wardrobe...too flimsy)
My ID had taught us how to tell the differences between the 3.
Hence Im quite sure that your ID provides u with plywood which a lot of contractor are using.
Its the laminating finishing that is different, depending on preferences.
So I dont see why they are charging u higher when everyone else are also using the same type of wood.
Unless there is a 4th type of super duper wood that my ID did not show us.
Zhiz is right, u are the decision maker :)
More than 4th type of wood or material that can be used for cabinet.
1. OSB
2. Blockboard
3. MDF
4. Chipboard
Every ID/contractor say the same thing but if you comfortable with overpaying so much despite warning from members....cos its your money.
yah... i am not convinced with his claims... hence i did not settle on his quote...
the reason i talk to him again is to negotiate for a better deal...
he does not seem interested in negotiating
1. OSB
2. Blockboard
3. MDF
4. Chipboard
Yup, but the most commonly used ones are plywood.
Unless furion0000's contractor/ ID is able to tell them that they are going to use some really good good wood, I still think that the quote is too steep.
Already told furion0000 that the quotation is ex. unless the ID use chengal wood for all the carpentry works.
haha that true. only chengal will cost that much
Can i have your ID contacts so that i can get a few more quotes.
I personally think that your TV console is way too expensive but again I could be wrong, it depends on the material use.
I had just replied 2 other forumers on my quote...since yours is condo too the height is 2.9m
Im going to type in word for word from my quote here:
1) Master Bedroom
- Custom make 8.5 ft (L) full height wardrobe with sliding door + finishes with solid plywood, selected laminate, mirror and ABD trimming door
- Custom make 1 set of suspended king size bed frame with storage compartment, side table, bed head and finishes with solid plywood, selected laminate, cushion and lighting point
- Supply and install 1 13A x 2 double socket
- Supply granite top 10ft(L) at bay window
- False ceiling + cove lighting
- Install 1 light point at planter
- Change toilet bowl
2) Bedroom 1
- Custom make 6ft (L) wardrobe with sliding door (specs same as above wardrobe)
- Custom make 6ft (L) study table with drawers
- 3 units of suspended books cabinet 6ft (L)
- Supply 2 13A x 2 double socket
- Supply granite top 6ft (L)
- Supply labor to install 1 light fitting
3) Bedroom 2
4) Living and dining area
- Custom make 5 nos shelving inside DB box
- Custom make 14ft (L) designer TV console finishes with solid plywood, selected laminate, colored glass panel and ABS trimming door
- Designer area using gypsum board, finishes with plaster and paint
- False ceiling + light box + cove lighting for living and dining area
- Wall mirror feature for dining area
5) Others
- Indoor and outdoor painting
- Chemical washing
- Polish existing granite flooring
- Revarnish + lacquer for all doors, pacquet floor + skirting
- Paint all doors
- Replace existing switch cover
- Construct base for fridge and washing machine
Total cost: Appro. $15, 000
Maybe you can show us reno pic of your place?
Too many phantom members these days advertising own services
View progress of my renovation here.... www.kohnlee.blogspot.com
Pictures of carpentry is finally up :)
Just PM u contact of my ID :)
U can view progress of my reno works here... www.kohnlee.blogspot.com
