vios123
Ceiling Fan
Hi all,
Need some advice from the forumers out there. The height of my living room ceiling to the floor is appx 250cm. Quite low for a HDB flat right? Thinking of installing a ceiling fan, scared it might be too low. Though of getting Elmark brand, the one for low ceiling, 3 blades. anyone tried that one before? really need your advice.
Thks
Hi all,
Thks
-Weight of fan should not exceed 6kg.
-Clear height from finished floor level to fan blades should be at least 2.4m.
-Harden steel expanding bolt should not exceed 8 mm in diameter and penetration depth of steel plug should not exceed 40 mm.
did pass the criteria above?
http://www.hdb.gov.sg/fi10/fi10205p.nsf/WP...ks?OpenDocument
