Dejavee
Dejavee
Hi, Anyone has a recommendation for a good plaster board ceiling contractor?
The last one I engaged made no prior survey on my interior and when the workers came, start firing thousands of nails into the ceiling resulting in concealed electrical wiring shorted. Have to spend another 1.5k for electrician to troubleshoot and by-pass the short circult point(s). Took 2 days to restore electricity. Big headache.
So make sure u guys take note if you have conceal wiring. Do let me know if you have a one to recommend. Thanks ya...
you can try pin pin plaster design at defu line. they are cheap and they are wholeseller
Thanks but do u have their contact to share? Cheers !
Can anyone comment if $3.20 psf for plaster ceiling supply and install consider expensive, reasonable or cheap? Thanks.
