michiko
Home & Furnishing: All types of doors
Dear all, just to share some pictures of the doors in my house
My main door:
Bedroom doors:
Shower screen door:
MBR toilet door:
Common toilet door:
Wow loving your bedroom doors. Mind letting me know the cost?
Thank you
Hi all, pls help!!
Anyone installed tempered glass door with height more than 2.4 meter? Coz my contractor said, no one will do this. Is that true?
can someone advise me?
I'm installing a fix tempered glass panel and a sliding OR casement glass door for my kitchen.
I can't decide which is a better choice.
If sliding door, I'm worried it will one day go out of track and fall?
If casement, when open takes up space.
Which looks nicer?
Hi donut88,
Base on the quote given should be veener door-S$280 (with door handle/lock). will drop by door plus to see tmr. Tks
my contractor quoted me $300 for each veener door w/o door frame....but said it's a hollow door..... :o
is your door a solid or hollow door? thanks.
have a qn.
some id said there's hollow and solid veneer door while others said all veneer doors are hollow. who is right here?
what's the price range for veneer doors?
thanks
Hi
I think for Veneer door, they have two type.. Hollow and Solid Door.. Hollow feels lighter whereas Solid is those of heavier type.
I was quoted by yontat at S$220 per door (installation and accessories)..
Doorplus quoted was 100 more for a similar looking door. Am excited to get it from Yontat.. will update :)
have a qn.
thanks
Veneer doors have hollow, semi-solid & solid.
when i did mine, i when down to factory to chk it out b4 i mk my purchase.
& i learn the following & hope that they can be help to you.
Hollow - typically using HONEYCOMB cardboard. which is extremely light weight & least durable
Semi-solid - filled with @ least 2cm wood strip in d door with maximum 20cm gap each. Heavier than hollow & more contact with glue thus more durable & less hollow knocking sound
Solid - Fully filled with wood with not gap within, mostly used for main door. most durable & most ex.
Hollow price are super cheap like $200+++ cos material used is very little.
Semi-solid are usually range @ $300+ cos they are solid wood strip & weight @ least 20kg more than hollow
Solid will cost u ard $400 for room & $500+ for main door which are thicker.
So here u have it. dont get charge for Semi-solid when they give u hollow doors.. haha
thanks for the explanation.
any knows roughly how much does a tic tac door cost? considering to build 1 for my store room.
Veneer doors for main door 有防火的吗?
this bathroom glass door cost $880 as stated in your signature right?
Yes, the glass door itself was $750 before GST. Then I requested to change the door handle which cost me additional $80 before GST.
After some negotiation, the total was $880 inclusive GST and installation.
Cheers,
