sunrisec
Preliminary Reno Budgeting
Making the wall smooth means plastering or?
Any idea how much it will cost for a 5I flat? 121 sq m.
Thanks!
My contractor quoted me 2300 for my 4rm. So you can roughly estimate your budget should be ard less than 3k. :D
Thanks!
my also 5 room was qouted $1900.
Thanks!
It depending, if for those wall that was hacked, it will be cement screeding to make it smooth then paint. For those normal wall, they just do plastering to make it as smooth as possible.
Cost for plastering whole hse is ard $2000 ~ $2500, some walls don't need to plaster then don't waste the $ on doing it, cos the workmanship of plastering doesn't mean that the wall will be straight or level, look smooth only.
my suggestion is not to go too much into comparing prices cos it will drive you crazy. also each house specs are different hence its hard to get forumers to give you accurate pricing as well.
Hope my quotation helps. Mine is 4rm 108sm. Just to give you a rough estimate.
DEMOLITION WORKS
To supply labour to hack whole house wall & floor tiles incl skirting
To supply labour to hack existing sink & stove support
To supply labour to dismantle bathroom & kitchen fittings
To supply labour to dismantle kitchen cabinet $ 3,050.00
WET WORKS
To supply & lay 600mm x 600mm homogeneous floor tiles c/w skirting to $ 5,650.00
living, dining, store & 3 bedrooms (tiles budget up to $2.70 psf)
To supply & lay 300mm x 300mm homogeneous floor tiles to kitchen & $ 1,950.00
2 bathrooms (tiles budget up to $2.40 psf)
To supply & lay 300mm x 600mm homogeneous wall tiles to 2 bathrooms $ 2,350.00
(tiles budget up to $2.50 psf)
your quote seems to be high....
The previous owner of the house did plastering before on all the walls, but some of them already starting to peel very badly. Should I choose to replaster the whole house? Or should I just plaster the affected areas? Any advices?
Thanks!
Thanks!
Just plaster the affected areas, save cost. If not a big patch, u can DIY too. :D
you can see my t-blog.
also plastered but then when you knock, you see the thick piece peeling.
hi Zhiz,\
not very sure is on the high side though but all together was quoted 25k after discount. :D
