dyleen
How To Remove Scratches On Stainless Steel Sink
My stainless steel sink is "disfigured" Anyone knows if there's any way to remove or make the scratches less obvious?
Everytime I see it, I feel so sad, but can't say much lor, cos hubby scratched it, and if I complain, he won't be very happy. :(
Can someone help me? :unsure:
Yes...u r able to do it...but it not easy... :)
Deep scratches or dents may be nearly impossible to remove, but surface scratches can be blended in by using a commercial-grade abrasive pad. A 180-grit pad or higher is a safe start. The main rule is to stroke or move the pad in the same direction as the existing grain. While blending in a scratch, you may create an area that looks different from the rest of the countertop. A light, feathering stroke will tone down changes. Another option is to hand polish the entire sink for a blended finish. Deeper marks require a more aggressive abrasive pad or a backer on the pad for more pressure.
hi jaskel, thanks for the reply.
the scratches are mainly surface scratch, swirl scratch.
The sink is a slight matt finish, so the "shiny scratch" stands out.
how to polish? can teach? make hubby go do polishing since he so 'chor lor' with the sink :P
