palmspring
Help Review Quotation
AGREEMENT
Demolish Work
1a To demolish existing floor & wall tiles at kitchen & backyard area.
1b To demolish existing 5ft(L) wall including glass door at kitchen entrance.
1c To demolish existing 15.5ft(L) wall including door & frame at store & guest toilet.
1d To demolish existing flooring at store & guest toilet.
1e To demolish existing partial parquet flooring at study room.
1f To demolish existing 9ft(L) wall including door & frame at study room.
1g To demolish existing L-shaped 7ft(L) wall at store outside study room.
1h To demolish existing 2ft(L) wall including door & frame at bedroom 3 entrance.
1i To dismantle existing top & bottom kitchen cabinet & backyard.
1j To dismantle existing wine display storage & partition storeroom at dining area.
1k To dismantle existing TV console, wall feature & panels **** area.
1l To dismantle existing study table, low cabinet, TV console panels at master room.
1m To dismantle existing vanity top, basin & mirrors at master bathroom.
1n To dismantle existing sitting WC at 03 bathrooms.
1o To dismantle existing 04nos swing door at 04 bedrooms.
1p To dismantle existing 04nos swing door at 04 bathrooms.
1q To dismantle existing false ceiling ****, guest bathroom & bedroom entrance. $3,000.00
Mansory Work
1 To supply & lay (600X300)mm matt homogenous floor tiles at kitchen area.(@$3.20/-psf) $1,020.00
2 To supply & lay (600X300)mm matt homogenous floor tiles at backyard area.(@$3.20/-psf) $520.00
3 To construct 50mm (thk) cement base for washing machine & tumble dryer in tiles finish. $130.00
4 To supply water proofing membrane at kitchen, Backyard & toilet area. $250.00
5 To supply cement screeding to smoothen wall at kitchen area. $920.00
6 To supply & install stainless steel rubbish chute including make good surrounding. $230.00
7 To supply & overlay (300X300)mm matt homogenous floor tiles at backyard bathroom. (@$2.80/-) $250.00
8 To supply & level up flooring with cement, foam sheet at store & guest toilet. $150.00
9 To supply cement screeding to smoothen flooring at store & guest bathroom. $200.00
10 To supply cement screeding to smoothen wall at store & guest bathroom area. $570.00
11 To supply & install 8ft(H) new wooden door frame c/w wood trimming at study area. $450.00
12 To construct 11ft(L) wall with 63mm hollow block to extend study room area. $770.00
13 To supply make good & cement smooth floor & wall at all affected areas. $380.00
Timber Flooring Work
1 To supply & install (Wood & Wood) engineering wood strip flooring size: (14mm X 190mm X 800- $9,600.00
1800mm) living, dining & dry kitchen area.
2 To supply & install partial new parquet flooring at study room. $420.00
3 To supply make good existing parquet flooring at bedroom 2. $150.00
4 To supply grinding & polish existing parquet at 04 bedrooms. $840.00
Plumbing Work
1 To supply & extend existing piping to new sink position at wet kitchen area.(conceal). $300.00
2 To supply & install inlet & outlet pipe for kitchen sink & washing machine. $180.00
3 To supply & extend existing piping to new sink position at dry kitchen area.(conceal). $200.00
4 To supply & install 02no hot water point piping at wet & dry kitchen area (conceal). $190.00
5 To supply labour to install longbath shower mixer set at master bathroom. $150.00
6 To supply labour to install conceal shower head set at common bathroom. $90.00
7 To supply labour for installation of 03 sitting WC master toilet. $225.00
8 To supply labour for installation of 02 vanity wash basin at master & yard toilet. $120.00
9 To supply labour for installation of 03 bathroom accessories. $105.00
10 To supply labour for installation of 02 storage heater. $180.00
11 To supply labour for installation of 03 mini Bidet spray at bathrooms. $120.00
Ceiling & Partition Work
1 To erect drop false ceiling for ducting aircon **** area. $580.00
2 To erect false ceiling at dry kitchen area. $320.00
3 To erect false ceiling at bedroom entrance. $180.00
4 To erect false ceiling c/w curtain pelmet backboard at master room. $920.00
5 To erect 9ft(L) full height partition board at new study room entrance. $450.00
6 To erect L-shaped 7ft(L) full height partition board at storage cabinet for linen. $320.00
Carpentry Work
A Private Balcony
1 To fabricate & install Chenghai timber decker flooring. $1,320.00
2 To fabricate & install L-shaped (L-4500X W-200X H-450)mm Chenghai timber planter box. $1,240.00
3 To supply & install Geo-textile & drain cell system inside planter's box. $450.00
B Living & Dining Area
1 To fabricate & install 7ft(L) low TV console with solid ply internal c/w colour polygon in selected natural $1,160.00
veneer finish.
2 To fabricate & install (9ft X 7ft) clear mirror c/w 3"(thk) wooden frame with solid ply in selected natural $1,820.00
veneer finish.
3 To fabricate & install 9ft(L) tall storage cabinet with solid ply c/w drawers & pull-out table internal colour $3,100.00
polygon in selected natural finish.
4 To fabricate & install 3.5ft(L) tall storage cabinet with solid ply c/w internal white PVC in selected $970.00
natural finish.
5 To supply & install 07 pairs (Blum) soft motion closet for drawers. $420.00
6 To supply & install 18 pairs (Blum) soft motion door stopper. $360.00
C Service Counter (Dry)
1 To fabricate & install 1.5ft(L) false wall with MDF board c/w frosted lami glass beside service counter. $340.00
2 To fabricate & install 5ft(L) 800mm(D) service counter & storage cabinet with solid ply c/w swing door $890.00
internal white PVC, aluminum recess handle in glossy laminate finish.
3 To fabricate & install (3ft X 5ft) Marble cut slab (White Volex) at service counter front panel. $650.00
4 To fabricate & install 12ft top & bottom kitchen cabinet with solid ply swing door, internal white PVC, $1,560.00
aluminum recess handle, 01no cutlery tray, 01no dish rack in glossy laminate finish.
5 To fabricate & install 21ft(L) Caesar stones quartz worktop. $3,990.00
6 To supply & install 03 pairs (Blum) soft motion closet for drawers. $180.00
7 To supply & install 10 pairs (Blum) soft motion door stopper. $200.00
D Kitchen Cabinet (Wet)
1 To fabricate & install 11ft(L) bottom cabinet with stainless (304) c/w open shelves in matt hair line finish. $4,620.00
2 To supply & install 10ft(L) stainless steel (304) panel c/w wood backing at kitchen area. $1,100.00
3 To fabricate & install 28ft top & bottom kitchen cabinet with solid ply swing door, internal white PVC, $3,640.00
aluminum recess handle, 01no dishrack, 01no cutlery tray, in glossy laminate finish.
4 To fabricate & install 2ft(L) tall unit with solid ply c/w aluminum recess handle in glossy laminate finish. $720.00
5 To fabricate & install 3.5ft(L) tall cabinet with solid ply to box up rubbish chute in glossy laminate finish. $850.00
6 To fabricate & install 28ft(L) 4"(H) bottom cabinet skirting with stainless steel (304) in matt hair line finish. $825.00
5 To supply & install 03 pairs (Blum) soft motion closet for drawers. $180.00
6 To supply & install 19 pairs (Blum) soft motion door stopper. $380.00
7 To fabricate & install 9ft(L) Caesar stones quartz worktop. $1,710.00
E Backyard Area
1 To fabricate & install 4.5ft(L) open shelves c/w table top for washer & dryer. $480.00
2 To fabricate & install 4.5ft(L) Caesar stones quartz worktop. $855.00
F Master Room
1 To fabricate & install (W10ft X H9.5ft) swing door wardrobe with solid ply c/w colour polygon in selected $2,950.00
natural veneer finish.
2 To fabricate & install 11ft(L) low headboard with solid ply in selected natural veneer finish. $1,060.00
3 To fabricate & install King size bedframe with solid ply c/w all pull-out drawers for storage below in $1,990.00
4 To fabricate & install 02nos bedside table with solid ply, colour polgon in selected natural veneer finish. $600.00
5 To supply & install 10 pairs (Blum) soft motion closet for drawers. $600.00
6 To supply & install 12 pairs (Blum) soft motion door stopper. $240.00
D Master Bathroom
1 To supply & install 5ft(L) light box with MDF board at ceiling. $150.00
2 To fabricate & install 5ft(L) top hung storage cabinet with solid ply c/w 02 side light box, full clear mirror $920.00
swing door, internal colour polygon finish.
3 To fabricate & install 5ft(L) vanity top with matching Marble & 5ft(L) suspended bottom cabinet $1,890.00
with solid ply c/w white PVC in laminate finish.
4 To supply & install 03 pairs (Blum) soft motion closet for drawers. $180.00
5 To supply & install 04 pairs (Blum) soft motion door stopper. $80.00
E Study Room
1 To fabricate & install 3ft(L) sliding door with solid ply c/w upper tracking & lockset in selected veneer. $800.00
2 To supply & construct 9ft(L) full height false panel with MDF board in paint finish at entrance. $870.00
Glass Panel/ Door &Bedroom Doors
1 To supply & install 14ft (L) fixed panel with 12mm (thk) clear tampered glass at kitchen entrance. $1,430.00
2 To supply & install 3ft(L) swing door with 12mm(thk) clear tampered glass c/w floor spring at $680.00
kitchen entrance.
3 To supply & install 03no swing door with solid ply c/w lever handle in selected veneer finish at 03 bedrms. $1,080.00
4 To fabricate & install 3ft(L) swing door with PVC finish at backyard toilet. $210.00
Others
1 To supply & paint whole house wall & ceiling with ICI emulsion paint. $1,800.00
2 To apply for haulage service includes sand/stock up/ clear debris by contractor. $750.00
3 (PE) structural wall for submission & endorsement. $500.00
4 To provide chemical wash & general cleaning for whole house. $530.00
5 To supply & lay protective covering for whole house flooring. $380.00
Total $78,180.00
No GST
AGREEMENT
Demolish Work
Mansory Work
Plumbing Work
Carpentry Work
A Private Balcony
veneer finish.
veneer finish.
natural finish.
E Backyard Area
F Master Room
D Master Bathroom
E Study Room
kitchen entrance.
Others
Total $78,180.00
No GST
Just my opinion
U can ask to reduce items highlighted in red. I am not sure about most of the carpentry works, since I am not doing much carpentry for my home. I have given below the amount my ID quoted for the highlighted ones. Hope it helps!
3 To fabricate & install 28ft top & bottom kitchen cabinet with solid ply swing door, internal white PVC, $2,800.00
1 To supply & paint whole house wall & ceiling with ICI emulsion paint. $1,100.00
2 To apply for haulage service includes sand/stock up/ clear debris by contractor. $300.00
BTW, my house is 4A HDB.
Need to know the floorplan dimension as unable to gauge for the tiling works pricing. Is this a condo or landed property?
AGREEMENT
Demolish Work
perhaps you can get another ID that agrees with you?
i think some are quite over priced.
Agree with zhiz, its totally over priced. There are forums on carpentry here.
If interested, can pm me to get my carpentry also.
PalmSpring, your ID is really overcharging u. becoz you also have a lot of carpentry works that are marked up. look for a few more IDs or contractors lor.
There are 4 bathrooms and a backyard.
It's either a private apartment or a landed property.
The quote may appear a bit on the high side if you compare item to item. But it's normal for a condo to be quoted slightly higher than a HDB and landed properties will be quoted even higher than condos.
Furthermore the quotation includes quite a number of quality materials. Not the kind the usual HDB dweller will opt for in reno and I think an ID would only recommend to someone who is willing to pay for elegance and quality. Looking at the materials and scope of works, the quotation doesn't seem that unreasonable.
JMHO.
