Jessy
J&j's Resale Home
Theres a door in between the MBR and bedroom 2, therefore we need to seal up that. The wall tiles and floor tiles for the kitchen and toilets we can choose up to $3.00 p.s.f ... The granite we choose is $6.50 p.s.f ...
I m still looking for maybe abit more discounts ... Would appreciate some suggestions and comments .. thanks!~
may i know y granite flooring ?
LIVING
01. To demolish whole house existing flooring, store room wall & wardrobe. $1600
02. Supply & lay china granite to whole house c/w skirting. $9640
03. Supply & install galvanized wrought iron gate c/w no plate $550
04. Supply & construct new store room with hollow block. $350
05. To re-open a new store room ent. $100
06. Supply & install wooden door frame and veneer ply door for store room $480
07. Supply & install L-box to living & dining area 18”. $880
08. Supply & install false ceiling at b/room access area. $150
09. Supply & install fire rated main door (plain design). $880
TOTAL: $14630
ALL B/ROOM
01. Supply & install 3 nos veneer ply door with slk 10 lock $960
02. Supply & install simple cornice to 3 b/room $750
03. Supply & construct hollow block wall to seal up existing room ent. $250
TOTAL: $1960
KITCHEN
01. To demolish wall & floor tiles, dismantle existing cabinet. $1100
02. Supply & lay homo. floor tiles $900
03. Supply & lay wall tiles $2400
04. Supply & construct cement base. $300
05. Supply & install s.steel rubbish chute. $160
06. Supply & install s.steel piping, sink & washing machines pvc outlet pipe, connect sink tap. $420
07. Supply & fabricate 14.5F top & bottom laminated cabinet c/w 1 set drawer, s.steel plate
Dryer with glass door, box up piping, all in soft close door $3045
08. Supply & install 13F solid surface work top $910
09. Supply & install alum cloth hanger $25
10. To demolish existing portion wall at ent & construct a new hollow block wall. $350
11. Supply & install ‘blum” accessories for kitchen cabinet. $260
12. Supply & install black glass backing. $585
13. Supply & install “besglas” alum glass sliding door at kitchen ent. $530
TOTAL: $10985
2 TOILETS
01. To demolish wall & floor tiles, two iron frame $900
02. Supply & apply chemical waterproofing. $300
03. Supply & lay homo. floor tiles $700
04. Supply & lay wall tiles $1800
05. Supply & install 2 way s.steel piping to 2 toilets. $400
06. Supply labour to install gallon heater. $120
07. Supply & install waterproof board to box up ceiling drainage pipe at master toilet. $250
08. Supply labour to install 2 set sitting w.c. $160
09. Supply labour to install 2 set washing basin c/w tap. $100
10. Supply labour to install 2 set toilet accessories. $80
11. Supply & fabricate 2F x 2.5F laminated hanging cabinet at master toilet $280
12. Supply labour to install 2 set shower mixer & shower head. $120
13. Supply & install 2 set alum adjustable lauver window. $320
14. Supply & install 2 nos “besglas” laminated glass bi-fold door at master & common. $1060
15. Supply & install 12mm clear tempered glass shower screen in 1 fix panel n 1 swing door. $480 TOTAL: $7070
OTHERS
01. Supply & paint whole house with under coat sealer & finish with emulsion paint. $1500
02. Supply & install whole house alum sliding window, kitchen casement window(orange glass). $1980
03. Supply & install galvanized wrought iron grills to living & front room $1200
04. Supply & install alum grills to 2 b/room & kitchen $450
05. General work: acid washing whole house, clearing debris. $300
TOTAL: $5430
SUB TOTAL: $40075
DISCOUNT: $2075
GRAND TOTAL: $38000
The above is a quote from my contractor. Any comments on it?? thanks..
Besglas alum sliding door for kitchen at $530 is very cheap... what are the dimensions, care to share? Also is it frameless - I dont know what "Alum" glass sliding door is ..
Edited by kaleidoscope
Alum stands for aluminium ... i dun have the dimensions with mi .. Got to ask my husband .. will share after i asked him
Also, Have you got other quotes? Maybe you should talk to a couple more and compare before you commit :)
ya ... Its after comparsion, then we decide on this contractor.. N we got a few changes to the things(example: the flooring, bi-fold doors) we wan to do in the beginning. This is the final list of things .. Was actually thinking if we can cut the price further or ask for more freebies..
check your PM
Hihi, asked my husband about the sliding door.. He says its with top n bottom tracks and the width should be about 86cm ..
