sanpokchubby 0 Report post Posted September 25, 2009 Hi all! I just received a quotation on the following carpentary works. Is it considered expensive? Supply & install sliding-door wardrobe with laminated finish (1900mm x full height) - $1460 Supply & install L-shaped top & bottom kitchen cabinet (Top: 3500mm, Bottom: 4850mm) - $3340 Supply & install solid surface top for L-shaped kitchen cabinet (L: 16ft) - $1616 Supply & construct L-shaped cement based for L-shaped kitchen cabinet - $380 Supply & construct cement based for washing machine and fridge area - $180 Supply & run piping for kitchen sink (sink & tap supply by owner) - $300 Share this post Link to post Share on other sites
jadens28 1 Report post Posted September 25, 2009 (edited) Hi all! I just received a quotation on the following carpentary works. Is it considered expensive? Supply & install sliding-door wardrobe with laminated finish (1900mm x full height) - $1460 Supply & install L-shaped top & bottom kitchen cabinet (Top: 3500mm, Bottom: 4850mm) - $3340 Supply & install solid surface top for L-shaped kitchen cabinet (L: 16ft) - $1616 Supply & construct L-shaped cement based for L-shaped kitchen cabinet - $380 Supply & construct cement based for washing machine and fridge area - $180 Supply & run piping for kitchen sink (sink & tap supply by owner) - $300 hi fren, base on the quotation given by my contractor, u shld be able getting ard 5 to 10% cheaper then this pricing. if u r interested i can give u the contact n compare price... Edited September 25, 2009 by jadens28 Share this post Link to post Share on other sites
sanpokchubby 0 Report post Posted September 25, 2009 hi fren, base on the quotation given by my contractor, u shld be able getting ard 5 to 10% cheaper then this pricing. if u r interested i can give u the contact n compare price... That's wld be great, please PM me the contact Share this post Link to post Share on other sites
jaskel 2 Report post Posted September 25, 2009 (edited) Hi all! I just received a quotation on the following carpentary works. Is it considered expensive? Supply & install sliding-door wardrobe with laminated finish (1900mm x full height) - $1460 $1365 Supply & install L-shaped top & bottom kitchen cabinet (Top: 3500mm, Bottom: 4850mm) - $3340 $2800 Supply & install solid surface top for L-shaped kitchen cabinet (L: 16ft) - $1616 $1280 need to know the brand...it will be better to gauge. Supply & construct L-shaped cement based for L-shaped kitchen cabinet - $380 $250 Supply & construct cement based for washing machine and fridge area - $180 $150 Supply & run piping for kitchen sink (sink & tap supply by owner) - $300 $200 Total Cost quoted to you: $7276 By right should be this: $5973 Saving: $1303 more than 10% saving. U r 'chopped' if u've done it. Edited September 25, 2009 by jaskel Share this post Link to post Share on other sites
jadens28 1 Report post Posted September 25, 2009 That's wld be great, please PM me the contact pmed u... Share this post Link to post Share on other sites
palmspring 0 Report post Posted September 27, 2009 $200 Total Cost quoted to you: $7276 By right should be this: $5973 Saving: $1303 more than 10% saving. U r 'chopped' if u've done it. I'm considering wardrobes as well - can you break down the cost by line to compare ? Share this post Link to post Share on other sites
jaskel 2 Report post Posted September 27, 2009 (edited) I'm considering wardrobes as well - can you break down the cost by line to compare ? Supply & install sliding-door wardrobe with laminated finish (1900mm x full height) - $1460 $1365 Supply & install L-shaped top & bottom kitchen cabinet (Top: 3500mm, Bottom: 4850mm) - $3340 $2800 Supply & install solid surface top for L-shaped kitchen cabinet (L: 16ft) - $1616 $1280 need to know the brand...it will be better to gauge. Supply & construct L-shaped cement based for L-shaped kitchen cabinet - $380 $250 Supply & construct cement based for washing machine and fridge area - $180 $150 Supply & run piping for kitchen sink (sink & tap supply by owner) - $300 $200 Total Cost quoted to you: $7276 By right should be this: $5973 Saving: $1303 more than 10% saving. Edited September 27, 2009 by jaskel Share this post Link to post Share on other sites
jeslynsm 0 Report post Posted September 28, 2009 Supply & install sliding-door wardrobe with laminated finish (1900mm x full height) - $1460 $1365 Supply & install L-shaped top & bottom kitchen cabinet (Top: 3500mm, Bottom: 4850mm) - $3340 $2800 Supply & install solid surface top for L-shaped kitchen cabinet (L: 16ft) - $1616 $1280 need to know the brand...it will be better to gauge. Supply & construct L-shaped cement based for L-shaped kitchen cabinet - $380 $250 Supply & construct cement based for washing machine and fridge area - $180 $150 Supply & run piping for kitchen sink (sink & tap supply by owner) - $300 $200 Total Cost quoted to you: $7276 By right should be this: $5973 Saving: $1303 more than 10% saving. Hi Jaskel Do you know any good carpenter for my kitchen reno? Please PM me. Thanks. Share this post Link to post Share on other sites
jaskel 2 Report post Posted September 28, 2009 Hi Jaskel Do you know any good carpenter for my kitchen reno? Please PM me. Thanks. Had PMed u. Share this post Link to post Share on other sites
celineng 0 Report post Posted October 6, 2009 Had PMed u. Hi Jaskel Please PM me. Thanks. Share this post Link to post Share on other sites
vomitblood 0 Report post Posted October 7, 2009 hi jadens 28 & jaskel pls pm me carpenter tel no thaaks Share this post Link to post Share on other sites
jadens28 1 Report post Posted October 7, 2009 hi jadens 28 & jaskel pls pm me carpenter tel no thaaks pmed u... Share this post Link to post Share on other sites
vomitblood 0 Report post Posted October 8, 2009 pmed u... thks Share this post Link to post Share on other sites
blue_diamond 0 Report post Posted October 8, 2009 hi... not sure if i am too late...but i do have a good carpenter who u may want to try....he been doing up a few the forumer house...overall all of us are satisfied and happy customer...do let me know if u are keen ba. Share this post Link to post Share on other sites
jaskel 2 Report post Posted October 8, 2009 hi jadens 28 & jaskel pls pm me carpenter tel no thaaks PMed to u. Share this post Link to post Share on other sites
