Jessy
Help Needed With Reno To My House
I recently purchased a 4-rm HDB house 104 sqm and have been actively looking for an ID/contractor for reno, the house is in a condition where I have to reno the whole house from floor ceiling, piping,doors windows, electrical etc. And so far all the quotes I have got put my expenditure at close to 40k. However my friends tell me that it is really expensive but I can't figure out why the cost seems so high. anyone have any idea below is a sample of 1 of my quotations which is actually one of the lower cost ones.
Anyone have any useful insights on how I can reduce my cost? Also still looking for a reliable ID or contractor
LIVING
01. To demolish whole house existing flooring, store room. $1400
02. Supply & lay 600 x 600mm homo tiles to whole house c/w skirting (tiles below $3). $5150
03. Supply & install galvanized wrought iron gate c/w no plate. $550
04. Supply & lay design tiles at dining area. $300
05. Supply & construct new store room with hollow block . $350
06. To re-open a new store room ent. $100
07. Supply & install wooden door frame and door for store room. $450
08. Supply & install L-box at dining area 18”. $380
09. Supply & install false ceiling **** and b/room access area. $900
ALL BEDROOM
01. To demolish 3 nos iron door frame & touch up. $240
02. Supply & install 3 set wooden door frame & nyatoh door. $1350
03. Supply & install 4F x 9F false ceiling at master room. $200
04. Supply & install simple cornice to 3 b/room. $750
05. Supply & construct hollow block wall to seal up existing room ent. $250
KITCHEN
01. To demolish wall & floor tiles. $950
02. Supply & lay homo. floor tiles. $900
03. Supply & lay wall tiles. $2400
04. Supply & construct cement base. $300
05. Supply & install s.steel rubbish chute. $160
06. Supply cooker hob (glass surface) & hood. $550
07. Supply s.steel double bowl sink & tap. $180
08. Supply & install s.steel piping, sink & washing machines pvc outlet pipe, connect sink tap. $420
09. Supply & fabricate 14F top & bottom laminated cabinet c/w 1 set drawer, s.steel plate
Dryer with glass door, box up piping, full height in oven area, all in soft close door. $2950
10. Supply & install 8F solid surface work top. $560
11. Supply & install alum cloth hanger. $25
12. To demolish existing portion wall at ent & construct a new hollow block wall . $350
13. Supply & install alum pvc sliding door at ent. $280
2 TOILETS
01. To demolish wall & floor tiles. $700
02. Supply & apply chemical waterproofing. $300
03. Supply & lay homo. floor tiles. $700
04. Supply & lay wall tiles. $1800
05. Supply & install 2 way s.steel piping to 2 toilets. $400
06. Supply & install 25 liter ariston gallon heater. $380
07. Supply & install 1 nos alum bi-fold door. $230
08. Supply & install 2 pcs 10mm clear tempered glass shower screen (1pcs 800mm). $560
09. Supply & install 2 set sitting w.c. $480
10. Supply & install 2 set washing basin c/w tap . $400
11. Supply & install 2 set toilet accessiores (mirror, tower bar, corner shelve, glass shelf,
Hand spray). $360
12. Supply & fabricate 2F laminated hanging cabinet at master toilet. $280
13. Supply & install 2 set shower mixer & shower head. $560
14. Supply & install 2 set alum adjustable lauver window. $320
15. Supply & install tempered glass swing door in one side sandblasting. $420
OTHERS
01. Supply & paint whole house with emulsion paint. $1300
02. Supply & install whole house alum sliding window, kitchen casement window. $1980
03. Supply & install galvanized wrought iron grills to living & front room. $1200
04. Supply & install alum grills to 2 b/room & kitchen. $450
05. General work: acid washing whole house, clearing debris. $300
ELECTRICAL WORK
Supply & install
01. 4 nos s.c.v point. $400
02. 14 nos 2 x 13 amp double socket. $770
03. 2 nos 1 x 13 amp single socket $90
04. 1 nos heater & 1 nos hood point. $180
05. 1 nos 15 amp a/c point. $90
06. 4 nos telephone point. $180
07. 25 nos lighting point . $1050
08. 1 nos 16 way D.B box. $350
09. Earth born ring. $100
