wtc
Tiles Prices
Most of the quotes for tiles are usually $2.5 p.s, but how much more do you all spent on tiles? Between ceramics and homogenoues, which one is more expensive?
I think homogeneous tiles more ex bah...
Usually nicer, glossier homogeneous tiles can range from $3-5.50 psf. Of cos there are more ex ex ones.
Also depending on the size of the tiles, whether 600x600 or 800x800 =)
Firstly, the $2.50 sqft is quoted for which area ? Living floor, Kitchen floor or Toilet floor or Wall Tiles ??? no detailed infro given as hard to let you know.
Homogeneous is thinker than ceramic and normally ppl use homogenenous for flooring rather than on wall while majority ceramic is used on wall. Depending on which area are u referring to?? if you using Homogenous tiles for living floor, $3.00 above considered a good rate tiles while below $3 is considered normal homogenous tiles (glossy) as it is easy attrac the stain after a while ..maybe 6 months or a year later on...depending on your maintainace as welll
