lionbo
Super Noob Needs Help With Quotation!
Hi all, can some steady ppl help me see if this quotation is over priced? if so, where ?
this is for an old 4 room condo that im trying to do over
Total is close to 50k!!
Sorry, i am out of touch with market since 3 yrs back so im v blur. is this a normal pricing?
Anything below that is popping out as warning? i know alot of info is missing so its not fair to judge this ID but based on your experience, do you see any item that is "Wa lan eh!"?
thanks all!
Design & Co-ordination
1 To provide interior design and space planning with perspective drawing and layout FOC
2 To provide consultation on colour selection and material selection FOC
3 To provide site co-ordination FOC
(A) Preliminaries Works
1 All permit & PE fees & HDB/Management deposit By client
(B) Demolition / Misc Works
1 To hack existing wall and floor tiles and skirting @ yards & 2 toilets ) $1,550
2 To dismantle and remove existing kitchen cabinet @ kitchen )
3 To dismantle and remove carpentry @ master bedroom and other bedrooms )
4 To dismantle WC and basin for 2 bath rooms )
5 To hack wall between MBR and dining ) $1,300
6 To hack wall between BR1 and BR2 )
7 To hack wall for open kitchen concept )
8 To hack away existing kitchen cabinet base
9 To hack away tile skirting for living, dining, kitchen and 3 bed room ready for wooden skirting
10 To plaster smooth the above hack item $950
11 Haulage, cement and sand )
12 To provide protection for new flooring with corrugated paper ) $850
13 Debris removal )
14 Acid washing after cement work $200
( C) Masonary Works:
1 To supply material & labour to construct platform c/w laminate flooring @ living $3,610
2 To supply material & labour to lay laminate flooring c/w wooden skirting @ balance living & dining $1,660
3 To supply material & labour to lay laminate flooring c/w wooden skirting @ kitchen $590
4 To touch up and plaster wall ready for wooden skirting for living, dining and 2 bed rooms $250
5 To supply material & labour to lay laminate flooring c/w wooden skirting for 2 bed rooms $1,520
5 To supply material & labour to plaster smooth exposed wall @ kitchen $750
6 To supply material & labour to lay homo floor tiles @ yard ($2.80psf matl) $750
7 To supply material & labour to do water proofing @ yard $180
8 To supply material & labour to lay homo floor tiles @ common bathroom ($2.80psf matl) $750
9 To supply material & labour to do water proofing @ common bathroom $180
10 To supply material & labour to lay homo wall tiles @ common bathroom ($2.80psf matl) $1,550
11 To supply material & labour to lay feature wall tiles @ common bathroom dry area ($3.5psf matl) $750
12 To supply material & labour to construct shower kerb @ common bathroom $100
13 To supply material & labour to lay homo floor tiles @ master bathroom ($2.80psf matl) $750
14 To supply material & labour to do water proofing @ master bathroom $180
15 To supply material & labour to lay homo wall tiles @ master bathroom ($2.80psf matl) $1,550
16 To supply material & labour to lay feature wall tiles @ master bathroom dry area ($3.5psf matl) $750
17 To supply material & labour to construct niche @ shower area $360
18 To supply material & labour to construct shower kerb @ master bathroom $100
(D) Painting work / Ceiling Work
1 To paint whole house internal wall & ceiling in ICI/NIPPON emulsion paint $1,480
2 To design and construct false ceiling @ living & dining $1,280
3 To box up to sewage conceal pipe @ new MBR toilet $290
4 To construct partition to creat store room @ new living corner $750
(E) Glass Panels / Doors
1 To supply and install frameless tempered glass swing door for MBR bath $550
2 To supply & install frameless tempered glass fixed panel shower screen @ MBR bath $750
3 To supply and install frameless tempered glass swing door for common bath $550
4 To supply & install frameless tempered glass fixed panel shower screen @ common bath $750
5 To supply and install door frame for new store room $180
6 To supply and install wooden door for new store room $280
(G) PLUMBING WORKS:
1 To install washing machine in/out let )
2 To install sink in/out let )
3 To connect sink tap )
4 To supply labour to install bathroom accessories ) $550
5 To supply labour to install tank heater for 2 toilets )
6 To supply labour to install new basin and taps and WC bowl for 2 toilets )
7 To install conceal copper pipe for 2 toilets ) $1,200
8 To install conceal copper pipe for kitchen ) $800
(G) ELECTRICAL WORK (estimate)
1 To design, submit and obtain approvals from the relevant authorities testing and commissioning of the $250
electrical work
2 To supply and install the complete electrical system for the project, including necessary electrical goods $3,550
wiring, telephone, power, SCV, Fan, data points, isolator for aircon etc
(H) Carpentry works (finish in veneer or laminated plywood, internal finish w white polykem,Ht-8FT)
1. Kitchen
1 To design and construct kitchen bottom cabinet in solid ply laminated swing doors L-3600mm $1,440
2 To supply and install solid top surface for bottom kitchen cabinet L-3600mm $1,020
3 To design and construct kitchen top hung cabinet in solid ply laminated swing doors L-3600mm $1,440
4 To design and construct a tall unit for oven L-1200mm $1,120
5 To design and construct breakfast counter cum work top unit L-1200mm $800
6 To supply and install solid top surface for breakfast counter cum work top unit L-1200mm $680
2. Living / Dining
1 To design and construct display cabinet beside common bath L-900mm $840
3. Master bedroom
1 To design and construct full height walk in wardrobe L-3800mm $3,640
2 To design and construct full height display cum storage cabinet L-2400mm $2,240
3 To design and construct suspended vanity cabinet @ MBR toilet L-1200mm $600
4 To supply and install solid surface table top for MBR vanity L-1200mm $340
5 To supply and install top hung storage cabinet c/w mirror door above MBR vanity L-1200mm $720
4. Common Bath
1 To design and construct suspended vanity cabinet L-900mm $450
2 To supply and install solid surface table top L-900mm $255
Total $49,975
