jdanielsg
Help Me With A/c
am relocating my split units...
a few questions:
1. should my pvc trunking have condensation? if insulated properly due to the diff temp the room the trunking is in a/c is not on..... there is quite a bit of moisture...somehow I am not too convinced that if it is insulated properly this is supposed to happen.
2. armaflex or thermaltake.
3. coolserve the guys who installed this condesation a/c although was a huge improvement from before when my mother said water would be dripping all over the wall... but I still think its not the way it is supposed to be, they use black rubber insulation I think its 0 thickness I am not too sure. they are quoting me 750 to relocate and btw the relocation is nearer to the coil unit not further away. Creation air is saying they can do it for $500 with a long install warranty but how can one ever trust those sort of things... and they use thermal take.... so i need some advice on who to go with
Hi ,
My contractor charge me 450 for relocation of condenser unit or fancoil... you wanna call him and ask ?
Geoscapes customer service hotline 67482091.
Best Regards,
Kelv.
