Xan
Who To Go To For Air Con Installations
Hi everyone,
I'm new to tis forum. Am actually looking for some suggestions on who to go for reliable installations of air con sys.
Scenerio:
Its an pretty old 4rm flat with existing air con installed. After few times of servicing and changing of parts, the air con still doesn't look so good after all. Mayb its getting old :( Therefore, am looking ard to see if anyone can help to suggest a reliable air con installer. The problem is, some of the pipings are behind some cabinets :bangwall: which is a headache. I foresee its gonna be a pretty big project jus to change the whole air con sys but well, we haf no choice.
Does haf a few installers in mind, CoolServe, GainCity, Hong Tar, Best Electronics etc. But dunno which one is reliable. Am Actually looking to install Mit sys 3 inverter if anyone could provide me with some feedbacks on tis air con sys.
Many Thanks in advance :)
Xan
Hi Xan,
Some information that u may find it useful.
Mitsubishi Starmex Multi Split (Inverter) R410A
http://www.mitsubishielectric.com.sg/index...emid=84#feature
Line-up of Inverter Multi Split System Air-Conditioners.
Our Inverter Technology adjusts capacity in response to conditions such as the difference between the outside and inside air temperatures, allowing our air-conditioners to run more efficiently and reduce energy costs. With capacity ranging from 2.5 kW to 7.1 kW, you can mix and match to build a customized air conditioning system that is just right for your home. We are the Best Choice for comfortable living.
If you still require more information again,
you may wish to contact me at kelvin@geoscapes.com.sg
www.geocool.weebly.com
Hi everyone,
Scenerio:
Xan
