Dear Tiler Seng
Kindy quote the below:
1) renovate 2 toilets and lay floor and wall tiles
2) renovate whole kitchen with cabinet and lay floor and wall tiles
3) Do cabinet kerb for Kitchen
Kindly pm me your email address so that i can sent you my floor plan for quotation.
Dear Tiler Seng
Have PM you
Hi tiler Seng, I would like to ask how much roughly would it cost to do the below mention for my new 4 rm premium HDB.
1)Hacking of living room tiles only and retile with homogenous tiles
2)false ceiling from living room to MBR.
3)MBR full height L shaped wardrobe.
4)small side dressing table
5)BR1 full height wardrobe.
6)Spraying of those coats at the kitchen and both toilets floors.
7)window grilles for all 3 bedrooms and living room
8)tv console
9)fixture walls to cover bomb shelter
10)tempered glass for kitch wall and door
11)a small display cabinet for my muscial instruments to be placed in BR2
12)both toilets shower screen
13)both toilets vanity shelves
14)Granite top for kitchen top and install kitchen cabinet
Btw, are u a contractor? or an ID?
if you are a contractor that means you do not do designed i presume?
i was an ID, my Tiler Partner is a contractor, ever since i joined venture with him i have become a half contractor, this is the calculation:
100% ID + 100% contractor= Half ID Half contractor (sounds like Arnold Schwarzenegger- Half Man Half Machine like that), that means you are... getting an ID as your contractor if you had engaged me :good:
Talk too much..btw i have PM you my contact ;)
Hi Tiler Seng
Could you PM me your contact details as well.
I will be collecting keys to a 4Rm New HDB flat and is sourcing for a contractor . :)
Hi Roselind, PM sent
Hi tiler seng,
My living room size is 3.6 x 6.6 meter.
Currently it is installed with ceramic tiles 45 x 45 cm.
May I ask, is it possible to overlay with homogenous tiles 60 x 60 cm without hacking? if can, How much will you charge?
If not possible, how much do you charge to hack and lay homogenous tiles for my living room? I will just use a standard tiles ($2.4/psf or cheaper)
This e-mail is confidential and may also be privileged.  If you are not the intended recipient, please delete it and notify us immediately.
You should not copy or use it for any purpose, nor disclose its contents to any other person.  Thank you.
Hi tiler seng
I would like to check out the cost of renovating kitchen and 2 bathrooms for my 4rm hdb flat (104sqm).
Note that we will still be staying in the unit while you renovate.
Items include:
Toilet
hack, overhaul, re-piping and laying
louvre windows for 2 toilets
bi-fold doors for 2 toilets
supply and install all accessories
Kitchen
hack, overhaul, repiping and laying
L-shaped concept with concrete sink support and stove support
carpentary for lower set of cabinets (upper cabinets not required)
If the price is right, when can you start renovating and how long it takes?
Hi Tiler Seng,
Can you give me an estimated breakdown cost for the following works in HDB 5 room flat.
1. Common Toilet - Hack wall/floor tiles and supply and lay wall/floor tiles with waterproofing. (tile $2.80 psf)
2. Common Toilet - Supply and overlay wall/floor tiles.(tile $2.80 psf)
3. Living Room - Hack floor marble with skirting (500 sqf)
4. Living Room - Supply and lay homogeneous tiles with skirting (500 sqf)(tile $3 psf)
5. Sand, haulage, debri removal
6. Living Room - L-box celing - 60ft
7. Plaster over existing rockstone finish wall and ceiling for 3 bedrooms
8. Painting of whole house 119sqm
9. Other associated charges
Thanks.
Hi Seng,
Can give a quotation for removal of existing floor laminates, then applying cement screed and a waterproof layer (industrial look) for a room of size 4.8m by 3.3m?
Please provide me your contacts too.
Thanks
