shsuya17
Relaminate Doors
  On 1/22/2014 at 12:26 PM, lyz77 said:
Does anyone have contact to laminated hdb fire-rated door? My existing door is lacquer finish and I am wondering if I can laminate it instead of replacing the door which cost over $1k.
Thanks in advance!
you need to check the depth of your door frame slit.
if you laminate over the existing main door, the door will be thicker. So there is a risk the door might protrude out instead of sitting flush with the frame.
Depending on your current lock set, it might not be able to re-use.
