i'm new to this forum, would like to hear views from fellow forumers on my reno quote.
Living /Dining
1 To supply and install storage cabinet C/W TV feature wall with TV console in selected $6,320.00
laminate finish with cove light effect.
L7000mm X H2400mm X D400mm
2 To supply and install dining table in selected laminate finish. $540.00
L1600mm X D800mm X H760mm
3 To supply and install 2 no. low sitting bench in selected laminate finish $860.00
L1600mm x H450mm x D450
4 To supply and install 5mm full height bronze tinted mirror to dining area. $920.00
L2100mm x FH
5 To supply and install selected designer range wall paper to foyer entrance $450.00
L1400mm x H3000mm
Kitchen
1 To supply and install full height storage cabinet in selected laminate finish. $720.00
L900mm x FH x D600mm
2 To supply and install full height storage cabinet in selected laminate finish. $720.00
Master bedroom
1 To supply and install extended wardrobe in selected laminate finish $1,060.00
L1100mm x H2400mm x D600
L900mm x H120mm x D400mm
4 To supply and install half height TV feature wall in selected laminate finish $410.00
L1500mm x H1200mm x D75mm
5 To supply and install suspended TV console in selected laminate finish $410.00
L600mm x H220mm x D500mm
6 To supply and install raise up platform in selected laminate finish $1,480.00
L2500mm x H100mm x D1400mm
7 To supply and install 5mm bronze tined mirror to bedside table area $440.00
8 To supply and install 2 no. wall mounted bedside table in selected laminate
finish
L500mm x H120mm x D400mm
L700mm x H120mm x D400mm $580.00
9 To supply and install selected cushion finish to bay window ledge $680.00
L2900mm H50mm x D500mm
10 To supply and install drawers to bay window ledge $590.00
L1500mm x H120mm x D500mm
11 To supply and install 2no. sliding table to bay window in selected laminate $880.00
finish including sliding mechanism
L600mm x H760 x D500mm
5 To supply and install selected designer range wall paper to whole room $1,800.00
Common bedroom
1 To supply and install solid surface top to bay window $770.00
L2700mm x H12mm x D500mm
2 To supply and install selected designer range wall paper to whole room $1,340.00
Common and Master W.C
1 To supply and install 2no. Vanity cabinet to common and master W.C $590.00
L600mm x H540mm x D500mm
2 To supply and install 6mm thk spray paint glass to vanity top $140.00
PAINTING WORK
1 To paint whole unit using ICI paint 2coat + 1coat base ( 5 colors ) $1,500.00
OTHER
1 To supply acid / chemical and general washing of entire unit before handing over. foc
2 To supply and lay protective corrugated cardboard for whole house flooring. foc
TOTAL $23,200.00
Am i getting a good price for the work done?? The ID is absorbing the GST.
Can i still bargain the price down??
The ID is very accomadating to all my request, are there anythings that i should look out for??
Thanks in advance.
Living /Dining
L2100mm x FH
L1400mm x H3000mm
Kitchen
Master bedroom
finish
Common bedroom
PAINTING WORK
OTHER
TOTAL $23,200.00
Thanks in advance.
U r doing all carpentry work and my guessing that this is a condo. Yes, u still can bargain the price further down some more.
