ossify
My Cosy Home In Holland
Last two V6 is finally up!
Hi ossify, saw that your alpha v6's rod seems shorter than the original rod.
Did you cut them? When fixed up to my bedroom, it feels miserably low. :(
Would it wobble should you cut them? esp high speed?
and does it require balancing? thanks in advance/
Nope, I did not cut them. Just remember not to stand on your bed :D
I wouldn't advise cutting them.
Without cutting them, it does not wobble even at highest speed. If your electrician installs it properly, it does not require balancing.
You need contact to get it at $290?
oic, thanks.
NP, i know where to get them..
you mentioned previously in your blog, A-lightings right? ;)
sorry, learnt also that the fans doesn't come with brackets, where to get them and would you
have any idea and how about a balancing is done?
Edited by dexufto
oic, thanks.
Yep, and if they quote you higher, just tell them the guy from Holland says it's $290 :D
I let me electrician handle the brackets and balancing. To me, as long as it works (no sound on top speed, lights can turn on), it's good :)
I've got the Fans a while back, thanks nevertheless,
Have installed them; my contractor got me the Bracket (was told that it does not come with one)
And when tune to speed 3 and above, it wobbles quite bad,
I'm kinda of concern.
The electrians my contractors hired doesn't seemed to know about balancing..
How do the electricians do the balancing, any idea?
That's scary.
So at speed 1 and 2, it does not wobble? The alpha V6 has a diagonal blade design so it may look like it is wobbling when rotating. What you should check on is the lamp in the middle. Is that wobbling?
So far, I have 4 alpha V6, have seen 2 other alpha V6 in a client's home, no signs of wobbling.
If yours is really wobbling, my guess is poor installation.
That's scary.
yea, wobbling is scary.
Speed 1 and 2 are fine.
Will ask my contractor to check with the electrician. Worst case will ask Alpha guys to make a trip down to check;
bepgof shares that there's a possibility of the bracket size; my contractor bought off the hardware stores.
Alpha pax also agress with that possibility.
Thanks for your input ossify.
Hi Ossify,
As you have joined an ID firm, pls note that soliciting business from your t-blog is not allowed. Kindly contact advertising if you wish to advertise your ID promotion offers.
Admin
Can you share your contractor num for Rj45
Hi There,
Can you help me to share the your contractor details for me to engage on RJ45 points cabling to my living, master, common room. Pls sms to my cell 81114094. Thanks in advance.
are ikea pax wardrobes of good quality?? would they last long??
am considering getting ikea pax too, but am concerned about the quality of ikea wardrobes.. help me out!
