joseeng 0 Report post Posted January 15, 2010 my area is schedule only at end-2010....still long long to go.... ........ mine is 2012...haiz Share this post Link to post Share on other sites
Rasp 0 Report post Posted January 15, 2010 Ok, thanks! But who can cut for me? Most of my contractors got cutting tools one all finished their work liao.... i buy saw and saw myself.... :-O Hi Gantan88, Are you referring to those bamboo poles for laundry hanging? If so, you just need to measure the length that you want, the shop will cut them on the spot for you to the measurement you provide. So no need to buy the saw and cut yourself. Try to get these poles near your new places because need to carry them back. By the way, you might also want to check the maximum length that your lift can take in when considering the length of the poles. Those 'un-cut' poles cant fit into the lifts. There's another type of laundry poles which are retractable when you turn them, like sun wukong weapon. For those, no need to cut and easy to keep also. Share this post Link to post Share on other sites
alamak 0 Report post Posted January 15, 2010 i got false ceiling,donno how they going to run the wire.. was wondering the terminal box MUST be near the TV~? not a must. the termination point is like the scv/telephone point. you can decide to place it elsewhere. just that your router/pc will be hooked on to the termination point in the future. Share this post Link to post Share on other sites
ossify 1 Report post Posted January 15, 2010 I am preparing for my OpenNet installation even though it's in 2 year's time Your Building is targeted for installation between Dec 2011 to Feb 2012. Share this post Link to post Share on other sites
ossify 1 Report post Posted January 15, 2010 (edited) bought Robina laminate flooring "White teak" at $3.30 psf w/GST Specifications Thickness: 8mm Standard: E1 Laminate Flooring Abrasion Class: AC4 Profile (Joint): R-CLICK® / R-LOCK® Dimension (WxL): 193mm x 1283mm / 196mm x 1288mm Surface: Normal Texture Panels per package: 8 pcs Warranty: 20 year for Residential & 15 year for Commercial use. Had a site visit to confirm measurements of my house for the floor laminates. Final cost in: 586sqft x $3.3psf + GST = $2069.17 Also have a free door trimming, and L trims instead of the usual skirtings. Thanks to Lena from Flooroption! Cheaper than expected will be installing my laminates next Friday Schedule for next week Mon: Aircon + plumbing Tue: plumbing finish Wed: Fixing lights/fans/switches Thu: Fixing lights/fans/switches + delivery of laminate planks Fri: Installing of floor laminate Edited January 15, 2010 by ossify Share this post Link to post Share on other sites
chipee 0 Report post Posted January 15, 2010 Hi ossify, are you engaging painter for your unit? Share this post Link to post Share on other sites
gantan88 0 Report post Posted January 15, 2010 i bought compact 707 at $165 For 707, she initially quoted me $190, on 2nd visit i told her outside selling as low as $160 - $180. Then she deduct $20 for me. So i got it at $170.... Share this post Link to post Share on other sites
gantan88 0 Report post Posted January 15, 2010 mine is 2012...haiz How you all check whether your block installation for opennet is when? My ceiling also all closed liao...... Share this post Link to post Share on other sites
gantan88 0 Report post Posted January 15, 2010 not a must. the termination point is like the scv/telephone point. you can decide to place it elsewhere. just that your router/pc will be hooked on to the termination point in the future. Yup, i think the first free 15m can pull all the way to the place you want the access point to be (usually is tv point) for most HDB flat. Unless yours is bungalow or wat... Share this post Link to post Share on other sites
gantan88 0 Report post Posted January 15, 2010 Had a site visit to confirm measurements of my house for the floor laminates. Final cost in: 586sqft x $3.3psf + GST = $2069.17 Also have a free door trimming, and L trims instead of the usual skirtings. Thanks to Lena from Flooroption! Cheaper than expected will be installing my laminates next Friday Schedule for next week Mon: Aircon + plumbing Tue: plumbing finish Wed: Fixing lights/fans/switches Thu: Fixing lights/fans/switches + delivery of laminate planks Fri: Installing of floor laminate Bro, what is L-trim? does it cost more? I am doing my flooring next week.... Share this post Link to post Share on other sites
gantan88 0 Report post Posted January 15, 2010 Hi Gantan88, Are you referring to those bamboo poles for laundry hanging? If so, you just need to measure the length that you want, the shop will cut them on the spot for you to the measurement you provide. So no need to buy the saw and cut yourself. Try to get these poles near your new places because need to carry them back. By the way, you might also want to check the maximum length that your lift can take in when considering the length of the poles. Those 'un-cut' poles cant fit into the lifts. There's another type of laundry poles which are retractable when you turn them, like sun wukong weapon. For those, no need to cut and easy to keep also. Yup, this is what i am refering to. Personally i still like the old school wooden pole, dun like the aluminium....i will go check out the shop, thanks! Share this post Link to post Share on other sites
gantan88 0 Report post Posted January 15, 2010 Hi Ossify, The shop that i went to quoted $28 for the laundry hook. Is this price reasonable? How much did you got it for? Share this post Link to post Share on other sites
lord vader 0 Report post Posted January 15, 2010 not a must. the termination point is like the scv/telephone point. you can decide to place it elsewhere. just that your router/pc will be hooked on to the termination point in the future. its not a must, but you should consider having it close to the tv point. if you place near the main entrance, there is no problem if you use a wireless router for your devices. but what if they have cable tv riding on the fibre later on? i dont think you can get wireless connection with your tv rite? then again, i could be wrong in that there are wireless tv Share this post Link to post Share on other sites
Mickey M 0 Report post Posted January 15, 2010 How you all check whether your block installation for opennet is when? My ceiling also all closed liao...... U can go opennet website and key in ur postal code. Just google or yahoo for the website - http://rollout.opennet.com.sg/. False ceiling is very flexible. It can be cut/make holes and others. Just have to patch it up and repaint again. The opennet ppl will probably not do it for u. But u can get ur contractor/worker to standby to assist during the installation in the future. Share this post Link to post Share on other sites
gantan88 0 Report post Posted January 15, 2010 its not a must, but you should consider having it close to the tv point. if you place near the main entrance, there is no problem if you use a wireless router for your devices. but what if they have cable tv riding on the fibre later on? i dont think you can get wireless connection with your tv rite? then again, i could be wrong in that there are wireless tv Think can plan the access point location according to your broadband need first. Tv now still on SCV cable. Hard to plan for everything at one go. Unless your Tv and broadband devices are around same place then will be easier... Share this post Link to post Share on other sites
