ossify
My Cosy Home In Holland
Day 20
3 men came today, finish plastering, painted base coat (oil sealer), started tiling
Overview of the house in the evening, painting oil sealer coat
Finishing touches of the plastering
One side of the shower almost done (overlay over blue tiles)
The other side was done wrongly (wrong colour)
Asked him to remove and replace with right one (matching colour) which took about 1 hour to remove and replace
Total cost for the day's work: $300
Hacking 50ft walls and clearing of debris: $1000
Accumulated cost for labour: $4100 (including clearing of debris)
Accumulated cost for raw materials: $2340.21
Total reno bill as of now: $7440.21
Discovered more chipped tiles. Have to workaround it.
Day 20
Hi ossify,
Great work well planned.... :good:
I still dont believe that you are not an ID or contractor.....you already shown that u are the 1.. :D .....
Cheers!
:yamseng:
Day 21
2 men came today, additional waterproofing, continued tiling, painting oil sealer, aircon people (3 of them) came to lay trunking
Overview of the house at noon
Additional waterproofing at edges after tiling done
Tiling in common toilet (blue separator tiles between WC area and basin area)
Tiles at WC area are the ones provided by HDB during the upgrading works done 2 yrs ago
Tiles near common toilet's entrance
Tiles on other side of common toilet's entrance
Total cost for the day's work: $200
Accumulated cost for labour: $4300 (including clearing of debris)
Total reno bill as of now: $7640.21
Natural Cool aircon trunking people supposed to come at 12noon, called me yesterday to ask for delay till 1pm, i asked them to come at 12.30pm. Today they came late at about 1.20pm, rather disappointed.
Discussed on trunking position for about 30min, rather pleased with end result. But sadly, they broke one of my tile, good thing it is not very obvious. Another tile was also slightly bent, although even less obvious. Reason why my tile broke was because they used concrete drill bit instead of tile drill bit. (will show pics in next post)
Edited by ossify
Trunking installation was done by Natural Cool
After 30 min planning discussion and 4 hrs of installation, here are the pics.
Chipping cement to make the hole bigger for water pipe
Insulation piping
Refrigerant tubing
Back to back mounting of aircon on beam in living room
In MBR
Edited by ossify
More trunking pics
Other side of MBR (above wardrobe)
Window side of MBR
Box-up of aircon pipe leading into drain
Cracked my tile, tiler tried to repair but still visible :(
Pipes outside my MBR
Had dinner with my wife at the nearby Nagomiya at Chip Bee Gardens
very lovely, will go back again :)
Nagomiya, a Japanese BBQ restaurant
Waitress cooking the special beef ribs for us
Zoom in on the fire
$32 for BBQ special beef ribs, salmon sashimi, mentaiko onigiri, appetizer calamari and ocha.
Guest Goobii
Bro ... trunking @ top no good leh.. water flow if not properly done will cause leakage or when condense can see water droplets.. this happens to my old house that is why mine is fix from high end to low end but above my skirting... .. Bed also not to be under it... fengshui no good also...
Anyway since already done... no choice.. hope you got no problem with the trunking later stage. Make sure your water drainage is maintained and suck out the dirty water whenever you service the 3 aircon...
Bro, thanks for info.
Anyway I can't do what you did (your picture below) because I am not getting built in wardrobe. I am also not custom making my bed/side tables to hide the trunking like what you did. I think my method is the best for my place already..
14432_170115323140_683288140_2902343_192
Anyway, my installers are from Natural Cool, they have high standards :D They used insulation foam to wrap the drainage piping. If any leakage, I call them to fix it :D
Anyway, I don't intend to do skirting, so no low trunking for me.
How often should I service the aircon?
I was a bit shocked that you use cloth to prevent cool air from escaping your MBR too :)
Edited by ossify
Guest Goobii
My aircon is the 12000BTU for master / 9000BTU for smaller room and the curtain is to reduce the cold air from escaping. The purpose of using 12000BTU is because not having any doors but just 1 curtain and those colour strips, even if I don't turn on the 9000BTU the aircon from my master room without the curtain is capable to cool both the room.
The main door is the GLASS panel. The concept is just like those cold storage FREEZER room and normal cold room. We almost wanted to get the AIR curtain just like those shopping centre but the price of it and the electrical bill we calculated is not worth to get it...
hope to see your final setup.... That will be your HOME SWEET HOME ~!
Servicing of aircon I would recommend you to do it every 3 or 4mth...
Edited by Goobii
Guest Goobii
er.. on a side note
WTS hamster @ $8 each, have 2 to sell
Bro ~! bring them to your NEW home la... ai yo .... such a cutee.... :rolleyes:
I can't... adopt... i already got two chihuahua dogs plus a baby...
er.. on a side note
I ask my wife want to buy not...let u know tomorrow
Day 22
2 men came today, continued with tiling and painting oil sealer, electrician came to do detailed measurements
Side of living room (previous bedroom 2) beside MBR, base coat of sealer up
Side of living room (previous bedroom 2) with window, base coat of sealer up
Overview of MBR bathroom
Toilet floor tiles
Accumulated cost for labour: $4500 (including clearing of debris)
Total reno bill as of now: $7840.21
Electrician/plumber and my tiler was discussing about tile cutting. Apparently my electrician/plumber has never heard of a tile drill bit before, rather disappointing. Together they cut some holes in my tile+wall, looks pretty decent. I think my tiler is a lot better at drilling holes in tiles than the electrician/plumber.
Day 22
I thought tilers only good at cutting tiles. They can cut decen tstraight lines without using a pencil/ruler to draw the line first. :D
No wor, my tiler has tools to drill holes in tiles too. My plumber/electrician is lacking in that.
