ossify
My Cosy Home In Holland
bought Robina laminate flooring "White teak" at $3.30 psf w/GST
[ig]http://www.robinaflooring.com/PopsUp/T23-L2.gif
Specifications
Thickness: 8mm
Standard: E1 Laminate Flooring
Abrasion Class: AC4
Profile (Joint): R-CLICK® / R-LOCK®
Dimension (WxL): 193mm x 1283mm / 196mm x 1288mm
Surface: Normal Texture
Panels per package: 8 pcs
Warranty:
20 year for Residential & 15 year for Commercial use.
where did u get your laminate flooring from? can share the contact?
robina is made in malaysia right?
Edited by alamak
I got it from Lena at Flooroption, 512 Sims Avenue, 6348 0078
Yeah. It's made in Malaysia with German technology. Can go to their website robinaflooring.com to take a look.
They are the sole distributor for both Pergo and Robina.
Pergo's family range and Robina is very similar in terms of specs.
Ask for a laminate sample if you're interested to test it out.
I tried scratching it very hard with the sharp corner of my cleaver and there were fine scratches, not detectable by touch, no split wood. If you do that with tiles, your tile would probably have deep scratches :P
I tried soaking it overnight in a pail, no bloating.
I think if it can withstand these 2 tests, daily use should be no problem :D
thanks for the contact and info. :)
would like opinions on this used sofa on sale at $100
is it worth buying?
from ikea website, says it's dyed split leather.
used for 2 years, can see signs of wear and tear in leather
retailing at $699 at ikea
Materials
Frame:
Solid beech, Solid pine, Cardboard, Birch plywood, Fibreboard, Particleboard
Leg:
Steel, Pigmented powder coating
Zig-zag spring:
Steel, Steel, Epoxy/polyester powder coating
Seat:
Polyurethane foam 30 kg/cu.m., Polyester wadding
Back:
Polyurethane foam 21 kg/cu.m., Polyester wadding
Armrest:
Polyurethane foam 25 kg/cu.m., Polyester wadding
Leather:
Through dyed split leather from cattle, with an embossed and pigmented surface, 100% polyurethane
is it worth buying?
Materials
Frame:
Leg:
Zig-zag spring:
Seat:
Back:
Armrest:
Leather:
2 options i can think of,
1) use and throw when it gets too jia lat
2) re-upholster for a new look, unless you really like the leather?
oops, it's actually 4 years old. owner provided receipt and 5 yr warranty card. so warranty is valid for 1 more year.
I think it'll be useful to reupholster it; even with the cost of the reupholstering, it would be less than the original price for the sofa.
for future reference, what's the estimated price to reupholster?
bought this 4yr old ikea klippan dyed split leather sofa with 1 yr remaining warranty for $100
Hi Ossify,
Read in some other thread that you are going for full height sliding glass door in your house.. could you let me know how much you have been quoted for it and what is the width of the entire thing... Also how many sliding panel and how many fixed... Pls give me your supplier's contact as well... Thanks :)
Specifications
Thickness: 8mm
Abrasion Class: AC4
Warranty:
nice...
the light color will brighten up the whole hse.
what's the diff between lcd and plasma?
why did ya purchase a plasma?
images not as sharp as lcd right?
or am i misled by marketing? :
hope ya don't mind the brainless questions....
nice...
thanks, my house is gonna be a white house :D
generally, LCD has a soft screen while plasma has a hard screen so it's more child-proof
LCD works better in daylight while plasma works better in night condition so if you like watching tv in dim conditions, plasma's better
plasma's colour saturation is richer than lcd
image sharpness depends on resolution. a hd-ready lcd and a hd-ready plasma are the same.
anyway, i bought plasma for 3 reasons.
1. i rarely watch tv and if i do, it'll be at night
2. the colour looks better too
3. it's $599 :D
3. it's $599 :D<---my fave reason!! :D
Hi Ossify,
I would recommend you to get quotes from Sun Sun Glass and Besglas.
Sun Sun Glass charges less for the glass, but their sliding mechanism seems expensive.
Besglas charges more for the glass, but their sliding mechanism seems cheaper.
So just get quotation from both and decide for yourself :)
Edited by ossify
went down to ikea today, saw one item that i wanted to use for my 6-seater dinning table :) bought at $50
GALANT
table top
160x80 cm glass black
Materials
Table top:
Tempered glass
Mounting plate:
Aluminium
Item Measurements/ Dimensions
Length 160 cm
Width 80 cm
Thickness 1.0 cm
