ossify
My Cosy Home In Holland
Guest Goobii
This rice cooker very nice... we intend to buy it ... but my CO adviced that we could actually use our microwave to cook rice... don't even need such... anyway waste of place to put..
In the end.... I think we just cook more pasta or porriage or maggie mee in future.. as We are not really a RICE person...
I have decided to buy a rice cooker due to the following reasons.
1) It uses less electricity than microwave (see here)
2) I can use the rice cooker to cook other things like pasta, etc. It's amazing how many dishes you can cook!
3) It will never burn your food, and safe, just in case you need to attend to your baby while in the middle of cooking
4) You can still use your microwave for other foodstuff while your rice is cooking.
I would use a rice cooker to cook porridge too :)
As for maggie mee, i'd use my induction hob. (more efficient than conventional microwave ovens) :D
Edited by ossify
1) It uses less electricity less microwave (see here)
how much is this model going for? i am eyeing on the Tiger 5.5cups one at isetan at $199.
I haven't checked the lowest prices yet, but IMM Best sells it at $188.
Does your family eat 5 cups a meal? :D
we don't but prefer to buy bigger in case our parents come over for meals.
met 1 contractor today willing to do hacking of walls only :D will get the quote by next week.
met another guy who is able to help me do up walls.
he told me that i shouldn't build new walls (changed position from existing walls) using hollow block bricks as they are very heavy so may affect the ceiling of my neighbour below. he advised me to use this "compressed air bricks" which is much lighter. i explained that i will need to put some cabinets and my chimney hood and he said he will add in metal supports.
anyone heard of this "compressed air bricks"?
finally found out the answer to this question..
The Lightweight Composite concrete block in this photo is 3 inches wide, 6 inches tall, and 12 inches long. A total of 8 - 16d common nails were hammered in without predrilling. There are no cracks.
In its lighter densities concrete absorbs shock.
The majority of regular concrete produced is in the density range of 150 pounds per cubic foot (pcf). The last decade has seen great strides in the realm of dense concrete and fantastic compressive strengths (up to 20,000 psi) which mix designers have achieved. Yet regular concrete has some drawbacks. It is heavy, hard to work with, and after it sets, one cannot cut or nail into it without some difficulty or use of special tools. Some complaints about it include the perception that it is cold and damp. Still, it is a remarkable building material - fluid, strong, relatively cheap, and environmentally innocuous. And, it is available in almost every part of the world.
Regular concrete with microscopic air bubbles added up to 7% is called air entrained concrete. It is generally used for increasing the workability of wet concrete and reducing the freeze-thaw damage by making it less permeable to water absorption. Conventional air entrainment admixtures, while providing relatively stable air in small quantities, have a limited range of application and aren't well suited for specialty lightweight mix designs.
Lightweight concrete begins in the density range of less than 120 pcf. It has traditionally been made using such aggregates as expanded shale, clay, vermiculite, pumice, and scoria among others. Each have their peculiarities in handling, especially the volcanic aggregates which need careful moisture monitoring and are difficult to pump. Decreasing the weight and density produces significant changes which improves many properties of concrete, both in placement and application. Although this has been accomplished primarily through the use of lightweight aggregates, since 1928 various preformed foams have been added to mixes, further reducing weight. The very lightest mixes (from 20 to 60 pcf) are often made using only foam as the aggregate, and are referred to as cellular concrete. The entrapped air takes the form of small, macroscopic, spherically shaped bubbles uniformly dispersed in the concrete mix. Today foams are available which have a high degree of compatibility with many of the admixtures currently used in modern concrete mix designs. Gecko Stone of Hawaii is currently experimenting with one such foam.
Foam used with either lightweight aggregates and/or admixtures such as fly ash, silica fume, synthetic fiber reinforcement, and high range water reducers (aka superplasticizers), has produced a new hybrid of concrete called lightweight composite concrete, or LWC.
Some other properties
Uses
Fire rated steel deck assemblies
Concrete frame
Bridge decks and girders
Precast / prestressed elements
Marine structures
Specified density concrete
Economy and Sustainability
Less weight (less dead load)
Reduced seismic inertia
Longer Spans
Better fire ratings
Better thermal properties
Thinner slabs or increased cross-over reinforcing
Decreased story height
Smaller structural members
Less reinforcing steel
Lower foundation cost
Reduced trucking and placement cost for precast elements
Less over-all material used
Performance
Excellent durability
Provides internal curing and water entrainment
Improved contact zone
Mitigation of micro cracking
Close elastic compatibility between aggregate and cementations matrix
Reduced autogenous shrinkage
Reduced chloride ion permeability
Guest Goobii
Bro ... ceiling fan V6 .. u may regret... even with brightest white 12v... the living room is still dim dim not bright enuff to read newspaper...
Lucky i got downlight therefore this V6 fan light will only be used when I want to watch movie and preparing for sleepy mode...
thanks bro, my ceiling fan light is for ambient lighting only.
i am getting 2x 4ft fluorescent tube for my 3m x 5m living room if i really need bright lights :D
anyway, if i want to read, i'll read at the study table
considering getting this for my living room as HTPC, will cost $850. :rolleyes:
Black Chassis with 512MB ATI Mobility Radeon HD 4330
AMD Athlon X2 6850e Dual-Core Processor (1.8GHz, 512Kx2, 2C)
Genuine Windows® 7 Home Premium 64bit (English)
2GB (1X2GB) DDR2 SDRAM 800MHz Memory
Dell Consumer Wireless Keyboard and Mouse Bundle
320GB SATA 3.0Gb/s Hard Drive with Native Command Queuing
Single Drive: 8X DVD+/- RW
Front Ports
Two USB 2.0 connectors
One headphone connector
One 4-in-1 memory card reader
Rear Ports
One microphOne connector
One line-out connector
One VGA connector
One RJ45 connector (10/100/1000)
two USB 2.0-compliant connectors
two eSATA connectors
one HDMI connector
Dimensions & Weight
Height: 197.6mm (7.8")
Width: 197.6mm (7.8")
Depth: 89mm (3.4")
Weight: 1.6kg (3.53lb)
Power
65 W with UMA
75 W with MXM Graphics card
Memory DIMM slots: 2 available
interested to buy this fridge (stainless steel colour), still sourcing for prices. lowest from Mustafa $1199 (best of 2 quotes)
Hitachi R-SF37SWPS
4-Door Solfege with A.I. Inverter Compressor & Nano Titanium Technology. Gross Capacity 438Litres
Key Highlights
Minus-Zero Cooling Panel
Intelligent Inverter Fan
Moldproof Door Gasket
Nano Titanium Deodorizer
Durable Tempered Glass Shelves
Auto Ice-maker
Quick Freezing Function
Nano Moisture Freezing
Door-Opening Alarm
Height Adjustable Shelves
Energy Saving Design
R-600a (HFC free Refrigerant)
Dimensions: 590W x 1798H x 615D
Edited by ossify
bought some cheap ikea furniture.
Besta Boas TV storage console - $179
Item Measurements/ Dimensions - Width 120 cm Depth 40 cm Height 128 cm Max. load 50 kg
nice fit for my 42" tv :)
Besta Shelf - $107
Item Measurements/ Dimensions - Width 120 cm Depth 40 cm Height 128 cm Max load/shelf 30 kg
for storage in living room, placed beside TV console
Abstrakt/Faktum wall cabinets (x2) - $201
Item Measurements/ Dimensions - Width 49.6 cm Height 91.8 cm Thickness 2 cm Max load/shelf 27 kg
for storage beside dining area
some curtain contacts to share with you all
Contact 1)
DIRECT FACTORY PRICE SALE OFFER NOW $3 PSF FOR VERTICAL & $4 PSF FOR ROLLER BLINDS
FREE QUOTATION , MEASUREMENT & CONSULTATION FOR YOUR HOUSE OR OFFICE
PLS CALL 8239 1721 JERRY NOW .. WE BRING SAMPLES TO YOUR DOORSTEP & OFFICE
Contact 2)
u can call Chia Min at 91504665 for quotation!
Recently,,,i went to his shop to alter my seater for my "bay window"
Was charge only $12 with double layer protection.
And i saw a small pillow so nice and compliments it!
WOW!!!!She gave me totally FREE!!!
Really 搤街坊!!!
$520 for 4 sets of blinds
Contact 3)
The shop is at Racecourse road Block 681
If u coming by MRT,alight at Farrer Park MRT Exit B.
it link to this block!
This is the web site..
http://yarkly.com.sg
Yarkly Interiors Decorations... Your FRIENDLY CURTAIN STYLIST!
Established in 1972, Yarkly Interiors Decorations have been to countless number of houses to be their dream curtain stylist. Customer Service is our KEY to success, and our excellence excels beyond our after sales services.
If there are places you want to keep the lights out, corners you want to decorate, areas you want to beautify, hesitate no more! Call your one-of-a-kind Curtain Decorator / Stylist today! Call Yarkly Interiors Decorations and make your dream come true TODAY!!!
681 Race Course Road #01-311
Singapore
210681
6297 0070 / 6293 4708
6297 1572
Terence Goh M: (65) 9188 4287 Loh Chiat Min M: (65) 9150 4665
just bought a 2nd hand Pioneer 5.1 surround sound system for $80, white colour, will match my console quite nicely :D
Pioneer HTZ700
Sound System : 5.1
Audio System : Dolby Pro Logic II, DTS, Dolby Digital
Subwoofer Power : 75 RMS
Total System Power : 450 RMS
Active Subwoofer : No
Receiver : Integrated into the DVD
Bands Tuning : AM, FM
Number of Discs Accepted : 1
DVD Recorder : No
Disk Types Accepted : DVD-RW, MP3, DTS-CD, CD-RW, DVD-R, SACD, CD-R, SVCD, JPEG
Remote Control : Yes
Stands / Tall Boy : No
Edited by ossify
