francine
~~our Love Nest~~
Thanks coffee_o for sharing.. I went and bought my washer and dryer for my new house.. =)
You're most welcome. :) I informed others about the warehouse sale but I did not go myself hahaha :P cos my house will only be ready in Feb next yr so now I won't be able to buy also :(
Hi, is the Mayer sales still on?
Nope I think it's during last weekend only. But you can always give them a call to check it out :)
Edited by coffee_o
4 room Simplified (Corridor)
Total $26,000
ALL Hack floor Tiles and wall tiles whole unit $1,800.00
ALL Dismantle old kitchen cabinet and cornies $150.00
ALL Haulage $300.00
ALL Supply and rewire ALL electrical points $2,100.00
ALL Supply and install 14no. lighting point without halogen bulbs $490.00
ALL Supply and install stainless steel water pipings (cold water only) $950.00
ALL ICI/NIPPON PAINT for all internal wall and ceiling $1,100.00
Foyer Supply and install 1no. Wrought iron gate $380.00
Living & 3BR
Supply and lay 600mm X 600mm homogenous floor tiles $4,200.00
Living Room To Supply and install L-box $450.00
LIVING ROOM Supply and install lamintated shoe rack 7ft $900.00
LIVING ROOM Supply and install lamintated low cabinet / tv wall $250.00
MASTER BDROOM Supply and install laminated vanity cabinet c/w mirror $900.00
MASTER BDROOM full height wardrobe c/w sliding glass door 6ft $1,320.00
MASTER BDROOM Supply and install laminated study desk c/w top hanging cabinet $550.00
MASTER TOILET Supply and install tempered glass entrance door $520.00
MASTER TOILET Supply and install tampered glass shower screen w/o door 1 panel only $240.00
KITCHEN Supply And plaster chemical cement and make smooth wall $800.00
KITCHEN Supply and lay homogenous floor tiles $800.00
KITCHEN Supply and install laminated kitchen cabinet 15ft $3,150.00
KITCHEN Supply and install solid surface top for kitchen cabinet 12ft $960.00
KITCHEN Supply and install half mirror No.1 $480.00
KITCHEN TOILET Supply and change aluminium WPC bifold door $210.00
2TOILETS Supply And plaster chemical cement and make smooth wall $900.00
2TOILETS Supply and lay homogenous floor tiles,inc waterproofing $800.00
2TOILETS Supply and lay wall tiles $3,200.00
2 TOILETS Supply labour to install 2 toilet bowls $140.00
2 TOILET Supply labour to install 2 basin $80.00
what u all think cheap or average?
what u all think? is this quote reasonable? from ID firm not contractor.
4 room Simplified (Corridor) 83SFM
Total $29,990 including GST
Hack floor Tiles and wall tiles whole unit including Haulage $2150
Supply and install 1no. new wrought designer iron gate Wan Sern Model $480
Supply labour & material to plaster whole unit area inclu.ceiling $2490
Living Room To Supply and install 12" x 6"L-box $380
Supply and lay 600mm X 600mm homogenous floor tiles living,dinning &3BR $4245
Supply and install lamintated shoe rack 7ft $1200
t.v. console w/storages compartment laminate finish $850
half ht feature wall in laminate finish $630
install false ceiling Dinning area $150
full ht sliding wardrobe laminate ,2 locks sets $1480
install sliding window with 3 track in standard HDB color $450
Supply & lay 300mm x 300mm anti-slip homogenous floor tiles $590
Supply & lay 300mm x 600mm matt texture homogenous wall tiles $1350
Supply & lay 600mm x 600mm heavy duty polish homogenous wall tiles $1350
install 1no. BESGLAS bi-fold door with acrylic panel & $290
install 10mm tempered sandblasting glass door with designer handle $480
Design & construct suspended vanity cabinet in laminate finish L800mm $320
Supply labour & material to install choice of solid surface L800mm $160
Supply & lay 600mm x 600mm heavy duty matt anti-slip homogenous floor tiles $1200
Supply labour & material construct bases for kitchen cabinets in tiles finish in/c of waterproofing $250
install kitchen top & bottom cabinet in laminate finish with anti-slam motion $2090
Design & construct kitchen full ht kitchen cabinet in laminate finish with anti-slam motion $860
Supply & install selected solid surface kitchen top in/c $760
Supply labour and material to install glass backing to kitchen top L2100mm $450
Design & construct full ht kitchen cabinet in laminate finish@ Rubin clutch L900mm $640
Supply labour & material to change Rubin clutch to stainless steel with recess handle $180
painting whole unit using ICI or NIPPON paint $ 1000
Supply labour & material to paint sealer coat at kitchen area before colour paint $200
Plumbing Works and installtion of all accessories and WC $1200
Supply and install tampered glass shower screen w/o door 1 panel only $180
Half height tined mirror at dining area $450
FOC Stuff
Supply labour & material L3000mm curtain pelmet partition board for curtain $ FOC
Supply labour & material to lay 1 layer extruded Polystyrene Foam to level before laying tiles by HDB requirement. $ FOC
Supply labour & material to install 1 pull out mirror panel @ wardrobe area $ FOC
Supply labour & material to remove existing window before changing of window $ FOC
Supply labour & material to install shower kerb in tiles finish (sink in) $ FOC
Supply labour & material to lay 1 layer extruded Polystyrene Foam to level before laying $ FOC
Supply labour & material to wash 2 times whole unit using chemical acid. $ FOC
Supply labour & material to install clear mirror L800mm x Ht1000mm $ FOC
Supply labour & material 1no pix panel 10mm clear tinted glass to sink top L900mm $ FOC
Supply labour & lay floor protection board. $ FOC
i'm still looking for Electrical work, Lighting, Bathroom & Kitchen accessories purchase any recommendation for me?
Do compare prices with neighbourhood shops. I did and the discounted Meyer price still a tad higher than what those shops can offer.
Lightings think quite a number of forummers bought from ligtings.com so you might want to take a look
Bathrm and kitchen accessories have number of shops which you can look for. Thanks to one of the forummers (I forgot who le :P) who provide this map which is very useful
thank a bunch coffee_o :)
went over to lighting.com last weekend, think we are set to purchase from them, but why they can offer should a low price among all? how's the after sales service?
thus far i've not heard of any problems in regards to their after sales service so i think should be quite safe. Regarding the price, i'm not sure but based on their website, they will not deliberately mark up their price and give you discount thus their price is fixed :)
hi francine
you don't cook? noticed that you have an open concept kitchen. or are you considering a glass door?
looking forward to your 3D designs =)
hi francine
Hi dyleen,
ya we have a open concept kitchen, actually is bcos no one know how to cook, even my MIL LOL so kitchen mainly for boiling water and cooking instant noodles only :D i choose all white for my kitchen, 3D have to wait until this weekend den come out cos actually our project very rush i only confirm with the ID last mth in between keep changing our design add in thing, take out thing hehe, at first we're thinking to do a full glass door between kitchen and dinning but after discussion we decide to take it out bcos we got old parent staying with us not very advisable to have one if not they will keep nagging :P hubby keep complaining our ID very slow, but i find him very responsible already everyday i keep calling him chasing my thing he also nv make noise and still meet my requirement within the dieline, maybe he's too busy with others project ba
i bought my whole hse lightings from lightings.com
their after sales service is very very good. supposed to bring the spoilt bulb to get exchange for a new one but i have forgotten and they said it is ok, they can exchange for us first. they can provide very good advice too!
