juz_me
Our Home In The East :)
Seen Doc in SNEC on Tues. He said there is a tiny blood speck in my left eye. Did a eye scan too. Ask me to monitor and see him again in 2 weeks time. He said most patients - the blood speck will dissolve on its own. Hope it will dissolve on its own....I am in my late thirties but I have high myopia :(
hahaha, as expected right?! just monitor... it will dissolve but floaters will remain... have to live with it but it usually don't really bother u de
Hi Merryman,
Blood speck in your eyes - did your see parts of the lines wavy or fuzzy too? How long to recover?
Many thanks!!
Edited by juz_me
hi Adeline, pls take care of your eyes.
You use ah poh for air con? Just met him just now and he mention that "my friend" from Bedok is getting air con from him. So i guess should be you.
Hi Ivy,
Thanks. Yes - will be getting Ah Poh for aircon. I did mention I was recommended by you :)
Hi Merryman,
Many thanks!!
yea.... i had bloodspeck in my right eye in 2004, it stings badly if you put eye drop (probably due to damaged vessel)... i was monitored for 3mths appts, then 6mths all the way up to 2008, then I defaulted it. I say it will take few months for the vessel(s) to fully recover, but the floaters (your wavy/fuzzy lines), I'm still seeing them.... it won't go away le.. sad..
Hi Ivy,
hope u'll be happy with his service. Today he and his team came all the way to my house just to help me unwrap my air con and fixed up my air con remote control on the wall. so nice of them.
Thanks for your reply.
Erh...my blood speck is inside the eye that is not on the eye white. No eye drop given. According to the doc, I see parts of the lines wavy/fuzzy is due to the bloo speck inside the eye. Sorry, is yours same as my condition? sorry... feeling "kancheong"....
I too have floaters which will not go away... just hope it will not increase.
I forgot mine was in eye or eye white liao, quite long ago... eye drop was when I used it on my own, and don't they put something to dilate your eye to check your eye? i don't know if it is the same condition but i did have the blood speck and it healed up after a few months...
Yes - they did dilate my eyes for the check up but no prescription of eye drops.
Erh... if you can recalled seeing parts of lines - fuzzy/wavy..??
So sorry for asking so many questions. Thanks for all your replies. :)
Hope this helps: I know it's lengthy...a write up from my specialist...hope it gives more understanding :)
How are floaters treated?
For people who have floaters that are
simply annoying, no treatment is
recommended.
On rare occasions, floaters can be so dense
and numerous that they significantly affect
vision. In these cases, a vitrectomy, a
surgical procedure that removes floaters
from the vitreous, may be needed.
A vitrectomy removes the vitreous gel,
along with its floating debris, from the eye.
The vitreous is replaced with a salt solution.
Because the vitreous is mostly water, you
will not notice any change between the salt
solution and the original vitreous.
Floaters and Retinal Detachment
Sometimes a section of the vitreous pulls
the fine fibers away from the retina all at
once, rather than gradually, causing many
new floaters to appear suddenly. This is
called a vitreous detachment, which in
most cases is not sight-threatening and
requires no treatment.
However, a sudden increase in floaters,
possibly accompanied by light flashes or
peripheral (side) vision loss, could indicate a
retinal detachment.
What causes floaters?
Floaters occur when the vitreous, a gel-like
substance that fills about 80 percent of the
eye and helps it maintain a round shape,
slowly shrinks.
As the vitreous shrinks, it becomes
somewhat stringy, and the strands can cast
tiny shadows on the retina. These are
floaters.
In most cases, floaters are part of the
natural aging process and simply an
annoyance. They can be distracting at first,
but eventually tend to "settle" at the
bottom of the eye, becoming less
bothersome. They usually settle below the
line of sight and do not go away
completely.
However, there are other, more serious
causes of floaters, including infection,
inflammation (uveitis), a bleed, retinal tears,
and injury to the eye.
Who are at risk?
Floaters are more likely to develop as we
age and are more common in people who
are very short sighted, have diabetes, or
who have had a cataract operation.
A retinal detachment occurs when any part
of the retina, the eye's light-sensitive tissue,
is lifted or pulled from its normal position
at the back wall of the eye.
A retinal detachment is a serious
condition and should always be
considered an emergency. If left
untreated, it can lead to permanent visual
impairment or even blindness within
hours.
Those who experience a sudden increase
in floaters, flashes of light in peripheral
vision, or a loss of peripheral vision
should have an eye care professional
examine their eyes as soon as possible.
my eye drop was self put de, I think b4 i saw them... didn't know something was wrong till i went to check...
i just see floaters after that lor, how bad is your lines? look like floaters anot?! floaters can be wavy and fuzzy right?!
Familyof4 - thanks for the info on floaters
Merryman - right eye see straight line straight. left eye see straight line - does see the whole straight line straight, certain parts of straight line wavy/fuzzy....its not the floaters that cos it. I think there is a "grey spot"...that grey spot will see images wavy/fuzzt.... Haiz....Hope it will resolve on its own.... Thanks again for your reply.
Ask you folks huh...
I am changing all my windows grilles to white Powdered coat (sp?), the window - with green shade - is it nice to go with my floor? (My floor is mixed reddish brown and grey. Wall - intend to paint white....)
Thank you.
