mydreamhome2009
Pls Help On This Quote! Reasonable?
Hihi, to all forummers.
Pls help to assist on my quote given from my contractor.
Is is good or is any area that i can ask for discount?
Thank you very much for ur time n help.
Here r the quotes :
the title no the description s $
1 to hack off floor tiles in living, dining, 3bedrooms,
demolition 2 bathrooms, kitchen ,utility & balcony, wall tiles in
kitchen & 2 bathrooms & haulage services, disposal.
only included kitchen cabinet only. $3,200.00
construct 2 to supply & lay 600x600 homogeneous polish tiles in
living,dining,balcony,store, 3 bedrooms with skirting. $6,300.00
3 to supply & lay ceramic wall tiles in kitchen wall. $2,400.00
kitchen 4 to lay homogeneous 300x300 & water proofing in kitchen $1,000.00
5 to construct cabinet base . $250.00
guest bath 6 to supply & lay floor tiles & water proofing. $580.00
7 to supply & wall tiles up to ceiling heigh. $1,380.00
master bath 8 to supply & wall tiles up to ceiling heigh. $1,380.00
9 to supply & lay floor tiles & water proofing. $580.00
10 to supply & install new piping,kitchen , & 2 bathrooms
sink & basin inlet & outlet. $600.00
piping 11 to labour to install kitchen sink, 2 set basin,2 set w,c .
water heater & bath fixture. $550.00
L baox 12 to supply & install L box in living 45mm D x 125mmH.
& main entrance false ceiling. $950.00
false ceiling 13 to supply & install false ceiling in dining only. $550.00
carpentry works 14 to supply kitchen cabinet top & bottom.16.5 fl. $3,600.00
15 to supply & install solid work top 15fl. $1,425.00
16 to supply & install wardrobe in master bedroom 7F. $1,500.00
17 to supply & install small tv console & study table. $950.00
18 to supply & install 2 wardrobe in 2 bedrooms.7F $3,000.00
wiring 19 wiring works Estimate. $2,800.00
doors 20 to supply & install 3stes soilid door & door frame. $1,440.00
21 to supply & install 2 sets simple bifold door white panel. $400.00
Total : $34,835.00
Ad hoc itmes like sink, wc bowls, cooker, heater, taps all we got to buy ourselves.
It is kind of hard to tell from here. Because sometime it is te design of te furniture or some other special thing that makes it costly.
The best way is to look for a few contractor to compare pricing.
I can be of service if you need :)
Here r the quotes :
Total : $34,835.00
Hi, i just got my quotation today, maybe can try to compare, mine is 4A 104 Sq
1)To hack living/dining 3 bedroom, kitchen, 2 toilets, store and cabinet include permit and haulage $2500
2)To supply and lay Homogenous tiles 600x600 for living/dining store and 3 bedrooms $4500
3)To Supply and lay Cermaic Wall tiles for 2 toilets full height $2400
4)To supply and lay non slip tiles for 2 toilets $800
5)To supply and lay Ceramic tiles for kitchen flooring 300 x 300 $1000
6)To Supply and lay tiles for kitchen wall $2600
7)To supply and install Stainless Steel piping for whole house, include washing machine point and etc $900
8)To supply material & labour to paint whole house $1000
9)Labour only for fixing 2 toilet bowls $180
10)Labour only for fixing Basin $100
11) To supply and install 2 bi fold doors for both toilets $400
12)To supply and install shower screen at masterbed room toilet $450
13)To construct washing machine base and fridge base $350
14)Kitchen cabinet both sides total 15.5ft Suspended type $3100
15)Solid surface for the kitchen cabinet 15.5ft $1200
16) Store room shelving $200
17)To construct a 8ft shoes cabinet (Till window height only) $880
18)To construct a Featured wall and tv console **** $1200
19)Masterbed room wardrobe with Tv console total 12ft $2400
20)Common bed room L shape wardrobe 8ft $1600
21)False ceiling and L box for dining and living $1000
22) 19 nos of down lights $760
23)Main door entrance grill with hard coating $400
24) 4 x Smooth surface bedroom and store doors $800
FOC Modify existing wardrobe 6ft to fit into another common room
FOC Installing of sink, cooker, hod kitchen accesories
FOC Sealing of doors
FOC Bamboo pole holder
FOC Installing bathroom accesories
FOC Changing windows lock (Just to dismantle and rivet to Stainless Steel)
FOC install ceiling fan
Total amount $30720 after discount 10% $27648 i neg until $25500.
Maybe will slightly add a bit more things
Ad hoc itmes like sink, wc bowls, cooker, heater, taps, mini spray ownself supply
Will confirm the renovation and commit on 20th Sept (After Ghost festival)
Duration quoted was 6 weeks completion
Items bought during GSS was a 42'' Panasonic Lcd Tv $999, Seahorse recliner 3 + 2 Seaters $1400
More items coming up, planning....
mmm you didn't mention the size of your place? 5 room or executive I assume...
1) to hack off floor tiles in living, dining, 3bedrooms,
only included kitchen cabinet only. $3,200.00 (ex... $2800 ok ba)
2) construct 2 to supply & lay 600x600 homogeneous polish tiles in
living,dining,balcony,store, 3 bedrooms with skirting. $6,300.00 ok, if 4-room this is too ex.
3) to supply & lay ceramic wall tiles in kitchen wall. $2,400.00 ok
4) to lay homogeneous 300x300 & water proofing in kitchen $1,000.00 ok
5) to construct cabinet base . $250.00 ok
6) to supply & lay floor tiles & water proofing. $580.00 a little ex.. $450? but ok la.. mm
7) to supply & wall tiles up to ceiling heigh. $1,380.00 ok
8) to supply & wall tiles up to ceiling heigh. $1,380.00 ok
9) to supply & lay floor tiles & water proofing. $580.00 same as above.
10) to supply & install new piping,kitchen , & 2 bathrooms
sink & basin inlet & outlet. $600.00 ok
11) to labour to install kitchen sink, 2 set basin,2 set w,c .
water heater & bath fixture. $550.00 ok
12) to supply & install L box in living 45mm D x 125mmH.
& main entrance false ceiling. $950.00 ok
13) to supply & install false ceiling in dining only. $550.00 ok
14) to supply kitchen cabinet top & bottom.16.5 fl. $3,600.00 ok, fully customisable? will be nice if it's cheaper...
15) to supply & install solid work top 15fl. $1,425.00 ok
16) to supply & install wardrobe in master bedroom 7F. $1,500.00 ok
17) to supply & install small tv console & study table. $950.00
18) to supply & install 2 wardrobe in 2 bedrooms.7F $3,000.00 ok
19) wiring works Estimate. $2,800.00 WAH what is your wiring like? what does it include?
20) to supply & install 3stes soilid door & door frame. $1,440.00 I think ex. 1000 ok?
21) to supply & install 2 sets simple bifold door white panel. $400.00 ok
All that said.. I think some things must give and take. If you're comfortable with this person and can work with him... a little more is ok la. :)
Duplicated thread found in Renovation work
Here r the quotes :
the title
1 to hack off floor tiles in living, dining, 3bedrooms,demolition
only included kitchen cabinet only $3,200.00
Better breakdown the cost of Haulage fee. What abt debris fee?
Dismantling of your 3 room door? Dismantle of your toilet door? Dismantle of wiring?
construct
kitchen
Only cabinet base? How abt Washing machine & Fridge Base?
guest bath
master bath
piping
L box
false ceiling
carpentry works
What? 1ft for $218, made of teak wood ah?
mine only 1ft for $100+
For item 16 to 18, if you buy outside ready made one would be definitely cheaper by half.
wiring
Contractor Gotta spell out clearly how many lighting point and electrical point
doors
$1440 sure anot? my id install 4 door with key & lockset c/w door frames only $906.00
Total : $34,835.00
How come they don't include painting, plastering service?install toilet accessories?lay corrugated paper?provide whole hse acid wash?
patch up affected area after hacking?
Ad hoc items like wc bowls, sink, taps, cooker all we got to buy ourselves.
carpentry works
I think he is trying to mean both top and bottom (16.5 ft x 2 ) = 33ft
33ft/ 3600
$109/ft ba
If $218 per ft then most likely soft closing system and soild top included le ba
Hi All
Can please help to check if my reno quote seems reasonable. Mine is a resale condo - 1367 sq ft. Thanks, thanks! :)
Demolition Works
Dismantle existing kitchen worktop 1 Lot
Dismantle existing Tv cabinet @ living area 1 Lot
Hack off existing skirting @ platio area 1 Lot
Dismantle existing pedestal WC & vanity @ master bathroom 1 Lot
Dismantle existing dresser & display cabinet @ master bedroom area 1 Lot
Dismantle existing pedestal WC & vanity @ common bathroom 1 Lot
Clearing off debris
---------------------------------------------------------------------------------- Total Amount : $1,650.00
Masonry Works
Touch up defected areas @ master bathroom using matching tiles 1 Lot $450.00
------------------------------------------------------------------------- Total Amount : $450.00
Ceiling Works
Touch up defected ceiling area @ living, kitchen & passageway area ( electrical works ) 1Lot $450.00
Painting Works
Supply & apply 03 coats of ICI Dulux or Nippon paint to all internal walls & ceilings ( max. 8 colours ) $1,500.00
Total Amount : $1,500.00
Plumbing Works
Connect inlet & outlet piping for wash basin 2 set $300.00
Connect inlet & outlet piping for kitchen sink 1 set $150.00
Supply labour to install basin & pedestal WC @ master bathroom 1 set $220.00
Supply labour to install accessories @ master & common bathroom 1 set F.O.C
Supply labour to install basin & pedestal WC @ common bathroom 1 set $220.00
Supply labour to install accessories @ kitchen area 1 set F.O.C
Supply labour to alter & install kitchen sink & hob 1 set $100.00
---------------------------------------------------------------------------------------- Total Amount : $990.00
Glass Works
Supply & install mirrors @ living area ( 4ft X 8ft ) 1 Lot $800.00
Supply & install mirrors @ kid's room area ( 3ft X 7ft ) 1 Lot $420.00
Supply & install mirrors above vanity @ master bathroom area 1 Lot $480.00
Supply & install mirrors above vanity @ common bathroom area 1 Lot $200.00
Supply & install frosted glass backing @ kitchen cabinet area 10 ft $600.00
----------------------------------------------------------------------------------------- Total Amount : $2,500.00
Wooden Flooring Works
Supply & lay chengai wood @ platio area (3.7m/3.7m) 1Lot $4,125.00
Total Amount : $4,125.00
Door Works
Supply labour & material to revanish existing doors & frame 10nos $650.00
-------------------------------------------------------------------------------------- Total Amount : $650.00
Granite Top Works
Supply & install granite worktop for kitchen cabinet ( imperial black ) 22ft $2,200.00
Supply & install granite worktop as master bathroom vanity's top ( imperial black ) 3.5ft $350.00
Supply & install granite worktop as common bathroom vanity's top ( imperial black ) 2.5ft $250.00
--------------------------------------------------------------------------------- Total Amount : $2,800.00
Miscellaneous
Supply & lay protection sheet 1 Lot F.O.C
Clean up whole unit with chemical 1 Lot $200.00
----------------------------------------------------------------- Total Amount : $200.00
Electrical Works
Supply labobur to hack & conceal wiring @ master bedroom bedhead area 1Lot F.O.C
Supply & run new light points 5 nos $300.00
Shifting of light point 1 nos $50.00
Supply & install ceiling fan point 1 nos $100.00
Supply labour to dismantle & install new ceiling fan 1 nos $80.00
Re install existing scv & power point @ living area 1 Lot $250.00
------------------------------------------------------------------------------------------------ Total Amount : $780.00
Custom Made Build-in Furniture - All laminates from Germany or Italy with solid ply wood
Design & fabricate full height shoe cabinet cum divider in laminate finish @ foyer area 4.5ft $1,260.00
Design & fabricate suspended Tv console in laminate finish c/w glass panels @ living area 8ft $1,080.00
Design & fabricate display ledge in laminate finish c/w conceal metal bars @ living area (3 nos) 3ft $500
Supply labour & material to change existing Tv feature laminate @ living area $880.00
Design & fabricate inland kitchen cabinet in laminate finish
c/w 04 sides ABS trimming swing doors, designer handles & pull up worktop 3ft $750.00
Design & fabricate half height cabinet in laminate finish
c/w 04 side ABS trimming swing doors @ kitchen chute area 2ft $360.00
Supply & change existing rusty kitchen cabinet hinges to new hinges F.O.C
Supply & install wooden frame @ kitchen area 7ft $650.00
Design & fabricate suspended vanity cabinet in laminate finish @ master bathroom area 2.5ft $300.00
Design & fabricate suspended vanity cabinet in laminate finish @ common bathroom area 3.5ft $420.00
Design & fabricate display ledge in laminate finish c/w conceal metal bars @ kid'sroom area 3ft (3 nos) $375.00
Supply & install shelves @ kid's room wardrobe 5pcs $250.00
Design & fabricate display ledge in laminate finish c/w conceal metal bars @ master bedroom bedhead area 6.5ft $280.00
Supply & install cushion @ master bedroom low cabinet area 7ft $450.00
Supply & install shelves @ master bedroom wardrobe 5pcs $250.00
Change existing 04 nos. of wardrobe door to mirror doors @ master bedroom 4nos $720.00
-------------------------------------------------------------------------------- Total Amount : $8,025.00
Total Reno cost after discount etc : $23000
Hi All
Demolition Works
Clearing off debris
Masonry Works
Ceiling Works
Painting Works
Plumbing Works
Glass Works
Door Works
Granite Top Works
Miscellaneous
Electrical Works
If Condo, most contractor or ID would quote u more expensive. Your expensive item is carpentry and chengai wood. Just this 2 is cost 12K liao.
But overall is quite ok. As u already got so many carpentry work.
Hi hv u secured any contractor yet
Here r the quotes :
Total : $34,835.00
Can PM me your contractor? Mine is condo resale too and my quotes are rather pricey. By the way mine is only 1055sqft and my kitchen is quoted 30ft....apparently more than yours which i don't see how...also do you have problems changing your wc in MBR? Mine is wall hung type and I'm not sure if i will get chop for it as everything is concealed behind that marble wall...SEALED TOTALLY :o
hi All
Demolition Works Hi
Clearing off debris
Masonry Works
Ceiling Works
Painting Works
Plumbing Works
Glass Works
Door Works
Granite Top Works
Miscellaneous
Electrical Works
Edited by sng28
Hi, may i check if this quote is reasonable?
Professional Services
Design Consultation & space planning
Design Proposal & Perspective drawings
Selection of colour, material & accessories
Site coordination & supervision
Decoration advice
Living Area
Supply & install a false ceiling or L-box light holder in Living Area $1,880.00
Supply & install a raised 6" platform at window area $650.00
Design & fabricate a full height design panel feature wall (L7ft) $1,680.00
Design & fabricate a suspended tv console (L7ft) $910.00
Design & fabricate a full height shoe cabinet (L5ft) $1,200.00
Design & fabricate a full height mirror panel feature wall (L5ft) $1,200.00
Design & fabricate a full height design panel wall with cushion backing & mirror (L7ft) $2,100.00
Kitchen Area
Construct cement concrete base for kitchen cabinet & fridge (one side only) $280.00
Design & fabricate a top & bottom kitchen cabinet c/w ABS trimming (L24ft) $2,880.00
Supply & install a granite work top (L12ft) $1,200.00
Supply labour to connect sink & tap $150.00
Supply & install a tempered glass sliding door $780.00
Supply & install a tempered glass backing in between top & bottom cabinets $720.00
2 Toilets Area
Construct 2 nos of shower kerb in both toilets FOC
Supply labour to install 2 nos of instant heater / 1 nos of tank heater $120.00
Supply labour to install 2 nos of toilet accessories -
Supply & install a 10mm thk tempered glass shower screen in Master Toilet $550.00
Design & fabricate a suspended vaniy cabinet in Master Toilet $650.00
Master Bedroom Area
Supply & install false ceiling or L-box light holder $680.00
Design & fabricate a full height casement door wardrobe (L7ft) $1,680.00
Supply & install a cushion backing at baywindow area (L9ft) $900.00
Painting Works
Supply painting for all internal walls & ceilings for whole house using Nippon Paint $1,450.00
Supply painting for all doors, frames & pipes etc
Window Works (height up to 5ft)
Supply & install aluminium powder coated sliding window at Service Yard Area $650.00
Other Works
General cleaning & acid washing for whole house $300.00
Floor protection for the whole house $300.00
SubTotal : $22,910.00
7% GST : $1,603.70
Total Contract Sum : $24,513.70
is this the only contractor/id u went to?
if u go to ID should go get a few from IDs...to compare...
generally contractors are cheaper...
watch out for hidden costs.. good luck!
No, this is not the only 1 i went to. But just wanna seek advise if u can spot any "hidden cost" here?
And can u also advise is it a gd deal here?
Hidden costs may vary...
like for example...if the ID brings you around for furniture/lights purchase..they are actually earning comission for it. Thus the prices u get may not be the best...
Also, any lighting points? they are quoted seperately from your quotation right? will they be enagaing their own electrician to do the rewiring/points etc? if so ask for their rates...
Material wise.do they specify which matieral they are using for laminate? wall colors? some charge extra if u choose the colors/material outside of their recommended ones..
Granite work top - from which country? they might be using the china made ones...so the ones they quoted may seem cheaper than others coz of the country of origin...
Btw, your kitchen cabinate got ABS triming or not? if so..need how much?
Your cabinet got doors or not? Comes with handles? if u wanna change the handles...need to top up?
These are the stuffs I can think off my head...
Basically, just ask for specifics...u would be surprised they charge u this and that...so their quotes are actually not wholesome.
Maybe I should do another blog post addressing this. :)
Wow.. Thanks alot Bro for the comprehensive listing..
Headache leh.. dunno which to select.. haiz... Am now trying to meet up with the shortlisted IDs... and they are like abt 15 of them.. zzzzzzzzz
