garion 1 Report post Posted February 5, 2010 (edited) ya very nice but i noticed this ceiling. bubble formation. no sealing done? thanxs ossify.... ID says most prob due to aircon leaking from the floor above.... will have to get the neighbour to fix the leak... http://www.renotalk.com/forum/index.php?s=...st&p=503128 Edited February 5, 2010 by garion Share this post Link to post Share on other sites
garion 1 Report post Posted February 5, 2010 (edited) Hi, Care to share cost & contact of your wardrode carpentry ? Appreciate hi limike, below for your reference the prices stated are before discount.... Mike from http://www.baroquedesign.com/ Edited February 5, 2010 by garion Share this post Link to post Share on other sites
garion 1 Report post Posted February 5, 2010 common room pictures Swing door wardrobe - with normal white interior laminate, full slide out rails for drawers.... anti slam hinges for swing doors... had wanted to install anti slam drawer rails also... but works out to be too expensive... right partition with 2 swing doors.... and full height mirror mounted on door.... left partition with 1 swing door... drawers with lock... Share this post Link to post Share on other sites
garion 1 Report post Posted February 10, 2010 Picture of the kitchen view of kitchen from living room - it was actually larger but we moved the partition further into the kitchen to make space for the dining area bravo sink... to the right is the box up to the ugly pipes.... asked ID to put glass backing to the right to protect laminate from water splashes.... but put on half way stainless steel sauce rack from ID.... a bit too high but too late to do anything.... Share this post Link to post Share on other sites
garion 1 Report post Posted February 11, 2010 pictures of kitchen - part 2 drawers - comes with polykem internal (woodgrain in walnut colour) and full length pull-out sliding rails bottom mount pull-out wire tray basket from Song Cho (Welmi) - surprising not as expensive as expected compared other lesser known brands side mount pull out sauce rack from Song Cho (Welmi) - actually wanted to mount the cabinet door to the rack but carpenter advised against it Share this post Link to post Share on other sites
El Nino_Al Nito 0 Report post Posted February 11, 2010 garion, i like the pullout tray basket and sauce rack from Song Cho too... did you get from IMM? mind sharing how much each? think ur carpenter is right not to mount on the cabinet door...coz heavy stuff might coz it to sag over times? YNWA, El Nino Share this post Link to post Share on other sites
garion 1 Report post Posted February 11, 2010 garion, i like the pullout tray basket and sauce rack from Song Cho too... did you get from IMM? mind sharing how much each? think ur carpenter is right not to mount on the cabinet door...coz heavy stuff might coz it to sag over times? YNWA, El Nino hihi thanxs cant rem the price now... i go home chk then update you tomolo Share this post Link to post Share on other sites
garion 1 Report post Posted February 12, 2010 garion, i like the pullout tray basket and sauce rack from Song Cho too... did you get from IMM? mind sharing how much each? think ur carpenter is right not to mount on the cabinet door...coz heavy stuff might coz it to sag over times? YNWA, El Nino hihi, we bought the 2 wire basket and pull out tray for $680... hope this help Share this post Link to post Share on other sites
ossify 1 Report post Posted February 12, 2010 thanxs ossify.... ID says most prob due to aircon leaking from the floor above.... will have to get the neighbour to fix the leak... heh. your ID playing taiji ah? anyway, this is a common issue when you don't apply sealant to the plaster after plastering. you really think your neighbour upstairs has such a big aircon leak that it can go through their flooring, and into your ceiling? Picture of the kitchen stainless steel sauce rack from ID.... a bit too high but too late to do anything.... are you able to fit any plates in the rack? looks very small. maybe should move the top rack lower. so you can at least put your dishes Share this post Link to post Share on other sites
El Nino_Al Nito 0 Report post Posted February 13, 2010 hihi, we bought the 2 wire basket and pull out tray for $680... hope this help hey, thanks for the info! silly question, but $680 includes the runner and hinges right? if yes, is it those anti slam types? Share this post Link to post Share on other sites
garion 1 Report post Posted February 18, 2010 hey, thanks for the info! silly question, but $680 includes the runner and hinges right? if yes, is it those anti slam types? yes it includes the runners... but not the hinges... the hinges are part of the carpentry Share this post Link to post Share on other sites
garion 1 Report post Posted February 18, 2010 heh. your ID playing taiji ah? anyway, this is a common issue when you don't apply sealant to the plaster after plastering. you really think your neighbour upstairs has such a big aircon leak that it can go through their flooring, and into your ceiling? are you able to fit any plates in the rack? looks very small. maybe should move the top rack lower. so you can at least put your dishes thanxs ossify so my ID has been bullshtting us all along ..... is it a big job to apply the sealant? how long does it normally take? going to ask him to redo the ceiling heh so far quite ok for the rack.... we seldom do serious cooking so dun really mind that... Share this post Link to post Share on other sites
ossify 1 Report post Posted February 18, 2010 thanxs ossify so my ID has been bullshtting us all along ..... is it a big job to apply the sealant? how long does it normally take? going to ask him to redo the ceiling heh so far quite ok for the rack.... we seldom do serious cooking so dun really mind that... not a big job. just have to paint the sealant layer after plaster layer is dried. plastering a ceiling takes a day max if you do 3 layers of plaster. let it dry overnight. the next day paint sealant layer (use nippon oil-based sealer). painting the sealer takes at most 1 hour per layer, with 3 hours in between for drying. 2 layers would generally be sufficient. dish rack must be able to accomodate dishes, otherwise it shouldn't be called a dish rack Share this post Link to post Share on other sites
ericmar 0 Report post Posted February 18, 2010 hi limike, below for your reference the prices stated are before discount.... Mike from http://www.baroquedesign.com/ hi garion, Congrats! Is it possible to share ur complete quotation or could u pls email me for reference? I m thinking of considering Baroque now. Thanks. Eric Share this post Link to post Share on other sites
annjoy 0 Report post Posted February 18, 2010 Hihi! I love your wardrobe interiors! Did your ID propose to you to have those interiors or you specified what you wanted? Btw for your kitchen's fully extendable hinges, did those come at a separate price? I wonder how much my ID is going to charge me if I request for those... :/ Share this post Link to post Share on other sites
