saj
Stove Must Be Higher Than Sink (or Vice Versa)
fair enuff on the gua portion kekeke...
but anyway, the rules to follow on the stove placement would be,
1. no stove in the NW sector( 天门 )
2. no stove to be directly facing the door.
3. 2 feets of clearance between the stove and sink is minimum criteria...
pls correct me if im wrong or add on if i have missed something... :)
You are also quite knowledeable, where got dare to correct....haha.
As far as eg. 阳宅集成 there are many 'rules'. If you really practise by now you should know that the answer lies base on situation. Rules are just a guide.
Hi IVY
The more I read, the more I getting blurrr liao... :sport-smiley-004:
Understand your situation. I think shouldn't overly anxious about it unless its too close together. Whether one is higher than the other or not, its all about balancing. Whether it comes out a gua call 既济 或 未济 also have to depend on other factors.
Just imagine, water come out from tap....is higher than stove. Water reach basin hole....it is lower than than stove.
If water basin and stove not side by side, how can we talk about "gua"?
hi ivy,
we can all learn together ah... if you dont mind that is.. :)
and i totally agree with you on the rules... rules are just guidelines... for example, facing of the house got mountain, and the back of the house got water doesnt naturally mean its bad... if your water and mountain stars are in the correct place, the house is still deemed to be good mah,,, :)
hi ivy,
Hi, no i don't mind...me also still learning.
hi felix,
if my stove (and of course the kitchen) in NW direction, than how? What can I do??
thanks fr sharing......
is it possible to make changes to the direction of the stove?
and another question is, how is the master/father of the house doing??
hi felix,
not possible la. bought as resale hdb flat...
i m the father la... haha..
well not doing really well now.....
my current house NW and my future house also NW..... "wa kao"!!!
resale flat? you shld not re-use the stove left behind by the previous owners... the stove represents a new beginning... and also the mother of the house...
have you shifted in?? if you have no choice but to keep the stove there, then you got 2 choices...
1. buy an induction stove cooker... no fire...
2. buy a normal stove, but you will have to cook less....
hope it helps...
Edited by felixwong
Don't worry too much!! It is not always that bad. It depends also on other factors like how strong is your NW, the shape of your house, the Qi and etc. If hit you exactly on the head supported by other bad factors, the most is exhaustion especially from work. But its a good sign if you're still young what!! Also there are other remedies. Don't worry...don't worry.
no worry..
before i commit to buy this house, i have been going around viewing fr a while. got houses with other orientation but ended up with this unit haha.. so be it lo... fate la.....
just have to work harder :thumbs up:
you mind throwing out your date of birth with time and let me take a look?
maybe there are things tat can be done to help you? :)
no worry..
thanks so much... but i don't think i m ready to do so... haha
haha no problem... :)
hi master felix.... good day
I re-checked my house layout and wondering based on the below; my kitchen consider at North or North West?
Thanks so much!
Hi Gary,
Could you zoom into the kitchen and draw the stove location?
If the location of the stove is still not fixed, do avoid the areas on the left side.
If you dont mind waiting, I can put in the compass into the centre of the kitchen when I'm back in office tonight... That should determine for you which sector of the kitchen your stove can be in.
Hope it helps.
Thanks so much!
