RyanX
Need Advice For False Ceiling And L-box
Guest melancholic
  santav said:
hi melancholic,
may i have your false ceiling contractor's contact? i got an existing false ceiling with 14 holes (existing spotlights) which i needed patched and reopen to fit new spotlight fixtures. i realised spotlight fixtures these day are much smaller than the old type (about 5yrs old). many thanks!
Hi santav,
i'll PM you. But you might want to check with your electrician if he can patch it up for you as well. Most electricians can do such simple patch-ups (i.e. they don't have to install the structure for the false ceilings).
  melancholic said:
Hi santav,
got it! many thanks! will check with my electrician.....cheers! :)
Hi melancholic
Can I have the contact pls? May I know if this contractor help to fix up all the lightings or do i have to engage a electrician?
Thanks.
Guest melancholic
  Ericang said:
Hi melancholic,
Could you PM me the contacts too?
PMed you already.
  pmetsg said:
Hi melancholic
Thanks.
PMed you already. As mentioned to you, he only does false ceilings. You need to find your own electrician. But no harm asking if he has any electricians he work with. After all, in this trade, that's how people survive, by supporting one another, so I'm sure he should know someone.
  melancholic said:
PMed you already.
yeap hes got a partner specialising on electrical sector,makes the coordinating job all easier.. =)
What is the minimum drop down needed for a false ceiling? and a false ceiling with cove light?
Guest melancholic
Normal false ceiling, mine was only 6 inches. With covelight, not very sure.
Melancholic. Can you PM me the contractor's contact number. Thanks
I went to get a quote for my false ceiling with a L box light holder along one side of the wall.
Area is 7.45 m x 5.30 m.
L box is along the 5.30 m wall.
False ceiling $1150
L box $300
Lighting points @ $45 per point
Fan point @ $50
And a strange to me is $600 for workmen salary. Is this normal?
I am only doing the ceiling and no other reno works.
Guest melancholic
False ceiling $1150
L box $300
Fan point @ $50
Who did you get this quote from? From my calculation.. and based on what I got from my false ceiling contractor, the false ceiling should be no more than $900, and the L-box no more than $120.
Lighting point, depends on whether it is concealed or not. Concealed in ceiling costs more. But if the lighting point is going to be hidden inside the false ceiling, then you should be charged the non-concealed price. Fan Point is standard at $50. There is NO such thing as workmen salary.
If this is the pricing you are getting from my false ceiling contractor, tell him his pricing is way beyond what I had been quoted. And if no change, then tell him to forget it and update us in this forum so I'll stop recommending him.
Thanks for the advice. NO, it is not from your contractor. Can you pm me his number. Will he just do the ceiling job and nothing else?
Guest melancholic
He does ceiling work only.
He has electricians that he works with. I'll PM u.
  melancholic said:
Oops.. I haven't been checking for quite awhile.. so didn't realise so many people looking for contacts.. If you had PMed me.. I would have responded faster... ok.. will PM all of you now..
Hi Bro, can you PM me the contact. your mailbox is full. Thanks.
