rxsroc
Iron Gate Bolts
Hi there...recently a salesman came to approach me when i was at home saying the original bolts holding the iron gates up are not safe enough...cos theres only a small spot weld on the bolt whereby it can be sawed off very quickly and the whole gate can be lifted up...he suggest me to change to a stainless steel ones with better welding on it...Damage is $100 for 3 stainless bolts...anyone changed theirs or encounter this?...any advice?...Thanks!
pictures below:
The man claimed the circled part where the weld holding the top part of the bolt head can be sawed off..and the bolt free to lift up..
pictures below:
There is a discussion about this in sengkang forum. Somebody posted a reply he got from HDB which states that the gates provided by HDB are not easily removed even after the welds have been tampered with. I cut and paste.
HOUSING & DEVELOPMENT BOARD
Your Ref :
Our Ref :
Date : 12 Nov 2008
TEL : 65774218
FAX :
EMAIL : tcy5@hdb.gov.sg
Welder of Gate Hinges Going Around Selling Service
We refer to your email of 10 Nov 08 with regards to the above matter.
The wrought iron gate provided by HDB are installed with the following safety measures:-
a. Rivet pins are being riveted into the hinges.
b. At both sides of the door frame, there are 2 holes for the 2 protruding rods welded onto the wrought iron gate to be sitted inside to make it unremovable when the gate is in close position.
Even if all the rivet pins have been tampered with and were broken or removed, the wrought iron gate still could not be removed when it is in the close position. Hence, the gate provided by HDB is very safe.
Residents are advised to check/verify with HDB before they allow the self approaching contractors to install the additional safety features. And if the contractors persist in harassing them, they should report to the police.
Thank you for your feedback!
If you need any further clarification or assistance, you may contact our Technical Officer, Mr Chew Seng Teck at Tel No. 6577 4253.
Yours sincerely
TAN CHEE YET
SENIOR TECHNICAL OFFICER (H&M)
SENGKANG BRANCH OFFICE
HOUSING ADMINISTRATION DEPARTMENT
SENGKANG BRANCH OFFICE 118 RIVERVALE DRIVE #02-01 RIVERVALE PLAZA SINGAPORE 540118 TEL: 1800-2255432
