thyler_koh
Quote For 3 Rooms And A Raise Platform
Hi all,
Below is the quotation from a contractor to lay my 3 bedrooms with parquet and also a raise platform in one of the rooms.
Please comment. Is it reasonable ?
Teak Parquet Flooring : $3100
Supply & install 230x46x12 mm think Burmese Teak parquet flooing on prepared plywood platform
in(measured seperately)/on smooth & level screed (by others) including sand & varnish with 2 coats of melamine
(Natural) clear coaing for 3 rooms(Total =<450 sf)
Extra over cost to supply labour including trimmings for riser of platform - $90
Plywood platform:$570
Supply & construct 150mm high plywood platform using 15 mm think moisture resistance plywood backing
on smooth & level screed(by others)
Size 3.1m L x 1.8m W
Teak Skirting:$420
Supply & nail 70 mm high x 11 mm thick Teak skirting with rounded top edge(w/o recess & flushed with
the wall) including sand and varnish with 2 coats of melamine(natural) clear coating
(Total =<120ft)
Brass Dividing Strip:$90
Supply & install 9x3 mm think Brass dividing strip in between floor finishes for 3 doorways
Total :$4568(with GST)
