rainman321 0 Report post Posted May 21, 2009 Hi, wondering where can I buy the LED light tube (the small lights) mine is about 10 small bulb in a row. For those TV console type. Anyone knows where can I get it? Share this post Link to post Share on other sites
ocheeeng 0 Report post Posted May 21, 2009 Hi, wondering where can I buy the LED light tube (the small lights) mine is about 10 small bulb in a row. For those TV console type. Anyone knows where can I get it? Try Ikea. Saw them a few days ago. Share this post Link to post Share on other sites
Supersimon27 2 Report post Posted May 21, 2009 Sim Lim tower ?? Share this post Link to post Share on other sites
Aiky 0 Report post Posted May 21, 2009 Katong Shopping Center, on the 3rd floor. You can see the shop window with giant words LED from the main road. Specialises and sells all (as far as I know) kinds of LED bulbs. Share this post Link to post Share on other sites
yoongf 11 Report post Posted May 21, 2009 10 small LED bulb for 1 TV console? 7 inch screen? But I thot.. TV console suppose to have a warm glow.. which LED cannot create the same atmosphere. Shouldn't it be T5 tube? So far.. SimLim Tower level 3 is still the cheapest for LED tube. Share this post Link to post Share on other sites
four13r 0 Report post Posted May 22, 2009 10 small LED bulb for 1 TV console? 7 inch screen? But I thot.. TV console suppose to have a warm glow.. which LED cannot create the same atmosphere. Shouldn't it be T5 tube? So far.. SimLim Tower level 3 is still the cheapest for LED tube. FYI, You can have any kind of light color of LED. Advanced materials allow white color in high power, just recently in these few years. White = all spectrum of colors. Therefore, warm white = all spectrum of colors with slightly stronger amber. Some advanced LED, single LED can tune the color, less advanced ones use 3 LEDs on one die chip, to have RGB colors. I used to bandgap-engineered Laser diode (similar to LED but with built-in mirrors) Share this post Link to post Share on other sites
rainman321 0 Report post Posted May 22, 2009 FYI, You can have any kind of light color of LED. Advanced materials allow white color in high power, just recently in these few years. White = all spectrum of colors. Therefore, warm white = all spectrum of colors with slightly stronger amber. Some advanced LED, single LED can tune the color, less advanced ones use 3 LEDs on one die chip, to have RGB colors. I used to bandgap-engineered Laser diode (similar to LED but with built-in mirrors) Yup, u r powerful. Nowadays, LED can do lots of stuff and energy saving too. Oso easier to replace compare to tube as u can jus replace a certain part if it blows, unlike one whole tube. And it take lesser space too and more safer. Based on my own opinon. Share this post Link to post Share on other sites
12digit 0 Report post Posted May 27, 2009 FYI, You can have any kind of light color of LED. Advanced materials allow white color in high power, just recently in these few years. White = all spectrum of colors. Therefore, warm white = all spectrum of colors with slightly stronger amber. Some advanced LED, single LED can tune the color, less advanced ones use 3 LEDs on one die chip, to have RGB colors. I used to bandgap-engineered Laser diode (similar to LED but with built-in mirrors) Do we need a 12v transformer to use those MR16 LED bulbs or we just install the bulb directly into the MR16 housing? Share this post Link to post Share on other sites
four13r 0 Report post Posted May 27, 2009 Do we need a 12v transformer to use those MR16 LED bulbs or we just install the bulb directly into the MR16 housing? Most likely no need because MR16 uses 12V. I actually called www.prime-light.com.sg and they sell MR16 and they said can be used directly to replace halogen. Their MR16 cost about $35 (I don't know whether this is cheap or not, anyone can recommend cheaper MR16?). The good thing of LED you won't get heat. http://en.wikipedia.org/wiki/MR16#MR16-Compatible_LED_Lamps Share this post Link to post Share on other sites
12digit 0 Report post Posted May 27, 2009 Most likely no need because MR16 uses 12V. I actually called www.prime-light.com.sg and they sell MR16 and they said can be used directly to replace halogen. Their MR16 cost about $35 (I don't know whether this is cheap or not, anyone can recommend cheaper MR16?). The good thing of LED you won't get heat. http://en.wikipedia.org/wiki/MR16#MR16-Compatible_LED_Lamps thanks for your reply four13r ! i found cheaper MR16 LED bulbs at Sim Lim tower i think e shop is located on the third floor and price quoted is between $24-26 if i remember correctly. i need to find the namecard given by the shop's boss to check with him. Share this post Link to post Share on other sites
12digit 0 Report post Posted May 28, 2009 Most likely no need because MR16 uses 12V. I actually called www.prime-light.com.sg and they sell MR16 and they said can be used directly to replace halogen. Their MR16 cost about $35 (I don't know whether this is cheap or not, anyone can recommend cheaper MR16?). The good thing of LED you won't get heat. http://en.wikipedia.org/wiki/MR16#MR16-Compatible_LED_Lamps I just called and check with one of the technician, he said a transformer is need to run the LED MR16 bulbs. i wonder if there are any LED MR16 bulbs with built in transformer in the market. Share this post Link to post Share on other sites
ecolight 0 Report post Posted May 31, 2009 hi, wondering if you guys are interested in Commercial LED lightings i.e.spot light, downlights etc. can visit our temporary web at www.ecolight.com.sg cheerz~ Share this post Link to post Share on other sites
Supersimon27 2 Report post Posted June 4, 2009 hi, wondering if you guys are interested in Commercial LED lightings i.e.spot light, downlights etc. can visit our temporary web at www.ecolight.com.sg cheerz~ Hi ecolight , I am interested to get EL-MR16-5W Descriptions 1W, 3W, 5W 3*3W High powered LED Warm white 3k / cool white 6.5k Up to 270lm Beam angle at 15˚ or 30˚ Specifications CE/ RoHS Compliance Direct replacement for halogen bulk As i already have 2 halogen point in my house , can I just direct replace it or I really need a transformer ? Share this post Link to post Share on other sites
ecolight 0 Report post Posted June 4, 2009 Hi ecolight , I am interested to get EL-MR16-5W Descriptions 1W, 3W, 5W 3*3W High powered LED Warm white 3k / cool white 6.5k Up to 270lm Beam angle at 15˚ or 30˚ Specifications CE/ RoHS Compliance Direct replacement for halogen bulk As i already have 2 halogen point in my house , can I just direct replace it or I really need a transformer ? Share this post Link to post Share on other sites
12digit 0 Report post Posted June 15, 2009 hi, wondering if you guys are interested in Commercial LED lightings i.e.spot light, downlights etc. can visit our temporary web at www.ecolight.com.sg cheerz~ can provide us with more information like whether we need transformers to use the LED lamps and pricing? Share this post Link to post Share on other sites
