GrandPaPa
Feng Shui Tips
Is it true that some fsm will ask you to buy items that hang at the window (due to poison arrow external) and when he walked around your new house, he point almost all the window, means all the window need to hang the things.
How true is that?
depends on wheather you get a good or lousy feng shui master. hahaha
Hey alan26. Be nice. I want to hear what GrandPapa has to say lei.
The water from my water feature keeps splattering out. I thought it signifies 'lou cai', so I placed 4 pots of money plant next to it so the water won't go to waste ma.
Is it advisable, Grandpapa?
first of all, i dont know if you put your water feature at the right place. will need to take compass reading and plot the chart to determine.
assuming you put it at the right place, and the water feature support wealth, the plants being wood element will weaken the water.
different elements when put together will interact with each other.
GrandPaPa,
I read up this article and it said sofa is best to lean against a solid wall, which symbolise stability/no worries (wall along corridor not considered a solid wall) but our house layout is unable to do that. We have to put the sofa in the mid length of the hall. Dining area is behind the sofa. Is there any method to turn it in favour to us?
I have not encounter this problem before, let me try to check for you.
I realise there are questions comming in, i just want to clarify somethings.
i am not a feng shui master, i am a feng shui practitioner. I learn and practice feng shui and are currently training under a master. I try my best to answer those questions that i know, those that i dont, i will try to check with the feng shui master who is my teacher.
the reason why i am posting tips is because, i seen many people encounter "feng shui master" that give bad advise. and the school of feng shui they use are questionable. and i am very against feng shui master that insist people buy their special product to counter bad feng shui. all feng shui originated in ancient times from yi jing. in ancient times most of these feng shui items do not exists.
during the tang dynasty, feng shui was at its peak, many people from all over the world wanted to learn feng shui. as feng shui is something that the imperial family value greatly and do not want common folks to aquire the skills. So fake fengshui were taught. (mainly half true half fake). ended up now there are many bad feng shui schools and theory that does not work. I am trying my best to educate people on what is real and what is fake with my posts.
i have posted earlier in the tread the litmus test for feng shui master, there are some things you need to look for in a FSM before engaging them.
1) ask which school of feng shui are they using and when it orginated. if they cant even tell you that, better not engage them.
2) check if they carry alot of products. because, most likely you will end up having to buy them
3) if the feng shui master cannot predict what happen in your house in the past, based on the chart, most likely they cannot tell you want is likely to happen in the future. and i dont think they will be able to give you good advise.
4) if you are paying good money, make sure the feng shui master come personally and not send an assistant to come and take compass reading. from my experience, taking compass reading itself is an important skills. because nowadays houses are build with steel re-enforced in concrete, it will affect the small little compass needle. not to mention the electronics equipment that cause electromatic interferance, like ur TV, computer, fridge, even watches that the "masters" are wearing. taking reading under covered areas or near substation or cars will also affect readings. any mistake will result in the wrong chart calulated and the wrong advise given!!!! take not of this!!!
5) some "FSM" or assistant will take the reading and come back another day for analysis. it is better to engage a master that can tell you on the spot what is the advise and remedy required. you do not want someone to have to go back and refer to their books....
I have engaged several feng shui masters for my own home and non of them can deliver the results. It caused me much fustrations and also money, as i had to buy feng shui product. Just as i was about to give up, I was introduced to a feng shui master, only upon the last one, things change significantly. My bad business become good, i became president of one of the business club, i also started another new profitable business. relationship at home become great and my dad mysterious skin problem disappearred, best of all i dont need to buy those feng shui items. The last master professionalism and passion inspired me to learn about fengshui.
I hope my passion for sharing has not offended anyone.
Edited by GrandPaPa
Hi, the teacher you referred to is it the same as the one who gave free consultation here under "Bazi consultation by Mr Chong"?
No I dont know who is Mr Chong
Hello SPOI...same as your layout....sofa middle, behind sofa, dinning table....being looking for solution too. Or rather just leave it like that?
i checked and it doesent really matter if sofa is not supported by wall. so dont worry too much.
Hello GrandPaPa
Thanks for all the valuable pointers.
Glad I did not buy the items as rough calculation cost me roughly about at least $2k to $3k.
Also, I read online about fs and 1 point that tell the owners is that the house MUST BE CLUTTER FREE, KITCHEN MUST BE CLEAN AND NEAT. HOUSE MUST BE BRIGHT, FOYER (MAIN DOOR) LIGHT MUST SWTICH ON TO MAKE IT BRIGHT AT YOUR INSIDE THE MAIN DOOR AREA.
Am I right to say that?
I mean generally speaking without taking any compass or reading...a very basic approach to have a good and healthy living.
Thanks!
happy
Hello GrandPaPa
Thanks!
happy
yes, that is the most important and fundamental, house must be kept need and tidy. because if house is untidy and dirty, if good energy comes it will be minimized, if bad energy comes, it will be amplified.
Hi GrandPaPa
Thanks!
How about main foyer area? Should be bright right? My main foyer area face a long common corridor.
Plse advice.
Thanks alot!
I do have lots of questions to ask....pai sei pai sei......all very general practice...
HAPPY
Hi GrandPaPa
Thanks!
Plse advice.
Thanks alot!
HAPPY
bright is better then dark, but color and number of bulb do matters, avoid 2 or 5 bulbs.
Hi GrandPaPa
I thought of buying the LED lights.
It comes with 2 blulbs...a aquarish with a glass cover....
Is that ok?
Or must aviod 2 or 5 bubls?
Happy
Hi GrandPaPa
Is that ok?
Happy
total number of bulbs avoid 2 and 5
Hi "GrandPaPa",
care to PM me ur fengshui master contacts and charges u last paid. Thanks a million for ur advise and help.
regards.
