p_yanie
Help Needed On Aircon
Hi, hope to get some advise here..
I have a Toshiba Inverter for 6yrs. Recently, its not working. I called the agent for troubleshooting and they told me that the PCB at the outer unit is spoilt and a PCB replacement cost $900+.
And he added that bcos the PCB not working, he is not able to determine that if there’s any issue with the compressor.
Is there any way to get a 2nd hand PCB? If end up my compressor is faulty as well, then shd it be best to change out everything?
i got this contact for you, but i didnt personally engage him for any aircon service. he's been recommended by other forum users. I read that he's a honest air con guy.
9746 2194 Daniel
Call him and let him see yr aircon first.
i'm not earning anything by doing this.
Good luck.
Hi,im new and curious here. Would you like to share what's the update for your Toshiba Inverter system,did you manage to get Daniel to take a look,thanks
