oneterence
Remove Stain On Silicone Sealant
I got a problem removing the black stain on the silicone sealant use to hold the glass doors in the toilet. Any cleaning agent or method i should use to remove the unsightly black stain on the silicone?
Thanks
I tried using Mr Muscle . Just spray and let the foam be there for some time. Use a toothbrush, brush it off and then use water to wash . So far the result is good . Hope it works for you .
There are a number of Mr Muscle product, may I know know when one should i get?
Thanks
The bottle is orange in color . For molds .
I normally use normal bleach (Chlorox, etc) applied directly on the stain. Dissapears within minutes unless the mold is already growing inside the sealant. If already growing inside the sealant, only remedy is to remove the sealant and reapply a fresh one.
I have looked at the ingredients of the orange coloured Mr Muscle, it is Hypochlorite and surfactants only. The more usual common name of this two ingredients are plain bleach and plain detergent. For those who need a budget alternative to Mr Muscle can use bleach mixed with water then spray onto affected spots.
