Rasp
Our Home
pictures!!!!... heee rasp i want to see your current house condition... =p
Wow, you managed to dig this out from ermm.. don't know how many feets below. :P
Hee.. Im getting lazy to update my blog, didnt even finish the part 2 and 3. Ok, I think I need to brace up, will continue the 'leaking' stories... er.. later. :rolleyes:
I didn't took any picture of my current house condition, cause haven't really start the engine to do the reno. But I will try to take the kitchen one for you.
curious..where u stay??? hee northeastern side of sg... hougang??? cannot be serangoon right???
Hee.. after seeing your layout yesterday, I am also thinking that we might be neighbours. And its a yes to your question. I think its just the matter of how close we are. :dancingqueen:
My flat is in the midst of the HDB upgrading. Is your flat undergoing upgrading now?
hahaha yes to hougang or yes to serangoon???? :P
my flat completed lift upgrading and is currently undergoing upgrading on the surrounding..
But i think yours is in hougang.. based on your distance to mrt station..
Hi Poseidon_Gal,
My flat still going through the lift upgrading, so probably not the same flat. :D
I pm you on the answer to the question.
hihi Rasp
think i hack ur blog better. haha..
yup im planning to have my WM in the common toilet.
will not be installing any heater or shower facilities
so it will solely be a 'do business only' area :)
would love to see more pics as well!
hihi Rasp
Hi newnyew,
I see i see. Hee, my blog is so well-buried that I didnt notice its was hacked by you. Hee.. anyway, feel free to hack it anytime. :D
Ok, I am back to share the air-con story.
After shifting in for few months, we noticed that the aircon unit in one of the bedrm leaks (aka drip water from the unit). Thank god, we didnt have our tv or carpentry below it. Being 1st-time owner and didn't know what to do, we called in the air-con specialist to check. The conclusion was, out of gas and need chemical cleaning. So they pump the gas, do chemical cleaning and uses a special vacum cleaner to suck the water drainage pipes from the aircon to clear / prevent any clog that cause the water to leak out instead of flowing to these pipes.
After around 8months, the same air-con unit leaks again. Hubby decide to try out on our own first, hence we got a water vacum cleaner to suck the water pipes. And it works, thou we didnt really managed to suck anything out. That aircon didn't drip after the suck. Phew! Hee.. you guys might want to try this out if you faced problem like that but no guarantee that it will work. :)
And recently, I found that there is actually water dripping from the trunking near my mbr toilet. We didn't really notice it until one fine day, one of my envelope dropped below that area and the ink on it actually smudge. And hubby touches the underneath of the trunking and realised its wet. Gosh.. i guess its probably due to the condensation of the pipes. The dripping is those minor kind that doesn't cause a flood. Hence, we didn't notice it at all until this.
After these experiences, I guess we probably won't conceal the trunking within any carpentry/false ceiling and not to have any things under the aircon unit to avoid further hassle.
Just to share the picture that I have taken on the recent dripping from the trunkings.
Normal looking:
With the envelope below:
Edited by Rasp
how thick is ur pipe insulation? 3/8 inch?
Hi Poseidon_gal,
Sorry, I am not sure about the thickness. Probably need to wait til I change the aircon and take a look inside.
And btw, we just painted the whole house (including the trunking) around 1yr ago, the trunking look yellowish already.. and I noticed that its only on the trunking that are dirty-looking and yellowish...probably cause by the condensation also. I wonder if there are any paints that won't look so obvious if such condensation happens.
Hi Poseidon_gal,
Gd tip on the conceal trunking! The aircon installer had no other choice but to run the trunking into my wardrobe, but thkfully only a small portion n near the floor. Looking at ur leakage gave me the assurance that it was right not to let them run the bulk of trunking in my wardrobe!
Nice view u've got there. :)
Thanks. But after staying there, we didnt really stand at the balcony to admire the view. :rolleyes:
