ocheeeng
Our New Place
Guest toilet (Fengshui master said this area must have green color...hmmm..any suggestions?)
Masterbedroom toilet
(Note the full-height frosted window at the shower area...I think outside can see clear shadows at night)
(Need to do something about it...hmmm...maybe put up a shower curtain to block)
Edited by ocheeeng
Master bedroom
Strong afternoon sun (need solar film)
Will construct storage with resting area on bay window
Wardrobe
Just enough for my wife's stuff...mine will be in other rooms :P
Wall color themes given by Fengshui master:
Foyer: green
Dining: green
Living: green
Guest toilet: green
Guest bedroom: blue
Master bedroom: blue or pink or purple or wood or red
Study room: blue
Utility room: green
Guess it will be a green green house...
Thanks for the grats.
It is a new condo in Yew Tee.
I saw many units have already moved in or started renovation.
I signed my ID or contractor on 3 Mar 09 and now still discussing the designs :P
Edited by ocheeeng
Wah seems like your colour is GREEN! heh
Which private place is this? With pool... :) nice!
Fengshui master said my element is strong GOLD and my wife's is strong WOOD.
Green will be good for us :P
Contract with ID or rather contractor:
Master bedroom
a. Supply labour & material to install plaster board light pelmet with curtain groove line (90sqft)
b. Supply labour & material to fabricate window storage cabinet with solid ply wood,
veneer finish with lift top c/w heavy duty hydraulic piston lift suport c/w build in console player
(2950mm - cannot do after site visit because it will greatly reduce walking space :bangwall: )
(Likely will do a revised contract for this after finalising design)
c. Supply labour & material to install dresser cabinet with solid ply wood, high
pressure laminates, & strip mirror with extra fix door panel next to it
(cabinet: 600mm(W)x250mm(D)x2500mm(H))
Study room
a. Supply labour & material to install work station with set table in solid ply
wood, high pressure laminatess & ABS edging c/w top cabinet in solid ply wood,
high pressure laminate & glass door with aluminium frame
(3600mm - overquoted by double after site visit :bangwall: )
b. Supply labour & material to install window ledge in solid ply wood &
veneer finish c/w extension of ledge cum cabinet
(extension: 450mm, total ledge length:1600mm)
Living room
a. Supply labour & material to fabricate suspended shoes cabinet
at foyer area with solid ply wood, high pressure laminate & ABS trimming
(900mm(W) x 300mm(D) x 900mm(H)) x 2 set
b. Supply labour & material to fabricate TV wall feature **** room
1) 1500mm x 100mm laminate wall feature with stainless steel inlay
2) 600mm x 2700mm x 5mm wall paper
3) 1500mm x 300mm x 2500mm TV console in solid ply wood, high pressure
laminate & flip down glass door
(Depth of TV console seems too short to accommodate players)
c. Supply labour & material to install outdoor timber platform in chengai & varnish finish
at outdoor to level up planter area
d. Supply labour & material to install false ceiling **** room area with plaster board
& MS stel support finishing
e. Supply labour & material to install light pelmet at dining area with plaster board finish
Guest bedroom
a. Supply labour & material to install window ledge in solid ply wood & veneer finish
Mscellaneous
a. Supply labour & material to paint whole house wall & ceiling
(ICI: wash & wear, light & space, 3 in 1)
(Nippon: 9000 series or odorless)
b. Supply labour & material to install timber curtain at guest bedroom and studyroom in
Edited by ocheeeng
Some of the custom procedures that we have gone through:
Kai men (open door after collecting keys):
Mix rice (uncooked), salt and tea leaves.
Just throw the mixture at the main door and say some good words before opening.
Kai gong (to signify start of renovation):
Bring a hammer tied with red string and knock 3 times at the place suggested by the fengshui master.
Then the contractor can start any date/time after that.
Simple, short and sweet :)
Edited by ocheeeng
Master bedroom
Study room
Living room
Guest bedroom
Mscellaneous
Wow .. Nice House !!!
Hi Ocheeeng,
your condo very nice! May I know how much you did for the above listed items? Also, specifically, may i also know the breakdown of cost of doing up the baywindows in each individual room?
Congrates on ur new place! I stayed in Yew Tee for a while before. It's a nice place. Lots of people jog. hehehe
Angel81,
The surrounding areas of Yew Tee MRT have changed quite a bit.
Now got YewTee Point. YewTee Shopping Centre has also expanded (got a new cafe and also McCafe).
The MRT station itself have 2 foodcourts.
Some proposed designs given:
Dining area (green...green :))
Don't know the display cabinet flies so high... :P
Living room (wall is in apple white...cannot really tell it is green right?)
Masterbedroom storage on bay window
totally same as us!! Hubby strong Gold, me strong Wood (BIG tree in fact!!)
our FS master say Red and Green are good for us. so we r concentrating on more red :)
very nice hse u got there! ;)
