ocheeeng
Our New Place
Need to buy some plants as advised by FSM.
Currently, shortlisted desert rose (adenium obesum). The Chinese name is 'Fu Kwee Hwa' (Prosperity Plant).
Anyone got lobang where to get? My other half and myself don't have gardening experience....
Work done for 28 May 2009: General cleaning with acid wash
Finally can step onto the floors without getting the feet dirty.
The cleaning uncle really did a nice job.
Also managed to get some cleaning tips from him.
(1) Thinner
Don't use on any surface if you are not familiar with its properties.
For example, if you use it on your verneer door, the applied portion will change color :P
Uncle has a bottle but he does not want to give me :P
(2) Turpentine
Good for cleaning stains (such as glue, paint, masking tap residue) on surfaces other than stainless steel, solid top
Uncle gives the left-over (more than half a bottle) to me :)
(3) Window film / Solar film / newspapers
Newspapers are good for cleaning glass such as mirrors and window glass.
But if you have applied window film or solar fim on window glass, best not to use newspapers to clean as it may scratch.
Just spray glass cleaning solution and wipe with a cloth.
Edited by ocheeeng
thanks for e tip!
Uncle left behind a new tin of Turpentine and i was wondering what it is use for!
Miss out something:
Use a dry cloth to apply turpentine.
Don't wash the cloth after use.
Just leave it for next application.
(1) Thinner
(2) Turpentine
bro im going to have a tv wall like yrs too with tv and sound bar mounted. what if next time we change tv model and size, can the bracket still be used??? headache lah, tot of just buy a ready-made tv console will do. :(
hello,
A bracket normally can support a variety of sizes. For example, a bracket can support 40", 42", 46" and 50".
Lets say you change from 40" to 46", you can reuse the bracket since the mounting holes at the back of TV are according to some standard one.
However, if you mount your soundbar directly below your current TV without any allowance (i.e. top of soundbar flushed to bottom of your TV), then your TV cannot be changed to bigger size without shifting the soundbar down or shifting the tv mount up.
Edited by ocheeeng
State of unit before floor protection removal and general cleaning
Living
Kitchen (kitchen sink not in picture, cover removed for usage and now stained with paints)
MBR
Guest room
Study
Edited by ocheeeng
Work done for 29 May 09: Installation of phone-ordered L-shape store rack by Yee Sin
Short side 40" length, 20" depth
Long side 60" length, 16" depth
72" tall
12mm plywood with PVC finish...each plank of plywood can hold up to 100kg.
Cost: $210
hi there,
may i know for the initial 3d design photos, do u did it yourself or the ID do it for you??
im know nuts about renovation and now i dunno where to start on my apartment. =)
